[Qgis-user] GDAL utf-8 workaround
Vladimir Naumov sendmeoffer at gmail.com
Thu Nov 1 21:28:42 PDT 2012
Dear Sotiris,
the problem was fixed months ago. Try new GDAL 1.9.2
Regards,
Vladimir.
01.11.2012 23:30, S. Koukoulas (lists) пишет:
> nice one!
> I did something similar by saving Greek fields in a new table (in
> Libreoffice Calc) and then used a common field to join them back to the
> attribute table. This can also be used to change from other greek
> encodings to utf-8 (through Libreoffice Calc) - a workaround until the
> problem is fixed...
> sotiris
> On 03/23/2012 04:34 PM, Koos Hagg wrote:
>> Hi everyone,
>> Trying the value 'utf-8' (no quotes) in a .cpg file did not work for
>> me (caps or not)
>> But i did find that i could get around the problem for now by opening
>> my shapefile's .dbf with Libreoffice Calc, (which opens it fine) and
>> saving the dbf (save as, same name, overwrite).
>> So at least that's a simple way to fix that for the time being.
>> Koos
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
