[Qgis-user] GDAL utf-8 workaround
S. Koukoulas (lists)
sotkouklistes at gmail.com
Fri Nov 2 05:19:51 PDT 2012
many thanks for trying André,
I remember that in the past this wasn't an issue. Anyway, changing
version in the lab in the middle of a semester is not an option for me.
It is good to know where the problem lies and I guess we can work with
the workarounds for the time being.
best wishes,
sotiris
On 11/02/2012 02:14 PM, Andre Joost wrote:
> Am 02.11.12 12:37, schrieb S. Koukoulas (lists):
>> As an example try dowloading the SHP file from
>> http://geodata.gov.gr/geodata/index.php?option=com_sobi2&sobi2Task=sobi2Details&catid=16&sobi2Id=21&Itemid=
>> and see whether you can read the greek names (nomoi_okhe.shp)
> OK, tried it, and got it working, with qgis master.
> In Settings -> Options -> General, there is a checkbox
> [] Ignore shapefile encoding
> With this option shapefile encoding is done the same way as in Qgis
> 1.7.4, that is leaving it to qgis and not gdal.
> So you have to stick to the old version, use master or wait until Qgis
> 2.0, when this option will be available in a stable version.
> Greetings,
> André Joost
> Qgis-user mailing list
