[Qgis-user] Install multiple versions on Ubuntu
Etienne Tourigny etourigny.dev at gmail.com
Fri Nov 2 08:14:01 PDT 2012
you'll have to build and install one of the versions yourself
(preferably 1.9), and update various environment variables (PATH,
LD_LIBRARY_PATH) to run the custom version.
If you need any hints on setting up the parallel environments, let me know.
Etienne
On Fri, Nov 2, 2012 at 12:52 PM, Stephane Goldstein <s.n.g at gmx.com> wrote:
> Hello.
> I have QGIS Lisboa running on Ubuntu 12.04, and would like to also install
> the 1.9 version.
> If I do it through the repositories it will upgrade my version.
> Is there a way to have different versions installed ?
> Qgis-user mailing list
