[Qgis-user] Problem installing Profile plugin
Etienne Tourigny etourigny.dev at gmail.com
Mon Nov 5 10:32:08 PST 2012
sorry for the delay... I have just uploaded version 0.5.0
(profiletool) which fixes this issue, as well as 1.9 compatibility and
other UI fixes.
You need to enable Experimental plugins to get this new version -
please test it and give me your feedback.
Regards,
Etuenne
On Wed, Oct 10, 2012 at 5:44 PM, Guido Paliaga <gpaliaga at gmail.com> wrote:
> Thanks so much!
> Guido
> 2012/10/9 Etienne Tourigny <etourigny.dev at gmail.com>
>> On Tue, Oct 9, 2012 at 1:07 AM, Andre Joost <andre+joost at nurfuerspam.de>
>> wrote:
>> > Am 09.10.2012 02:23, schrieb William Kyngesburye:
>> >> Profile tool is a plugin affected by an incompatibility of PyQwt5
>> >> with recent PyQt versions.  It needs to be fixed to use another
>> >> graphing toolbox like Matplotlib.  Until then it will be broken in
>> >> the current QGIS.
>> Profile tool DOES support matplotlib - although perhaps it fails when
>> pyqwt is not found.  See attached screenshot, using matplotlib for the
>> plot.
>> I'll try to fix this by the end of the weekend.
>> > It also does not work on Qgis Master under Windows, but still works with
>> > 1.8.0 there.
>> > The author has promised me to rewrite the tool.
>> activity is very low, original author does not have any time to
>> dedicate on this.  I am working on some UI and functionality
>> improvements,  but I don't have he time to rewrite the tool.
>> > Greetings,
>> > André Joost
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> Dott. Geol. Guido Paliaga, PhD
> Mobile +39 335 6901747
> Skypeid: gpaliaga
> paliaga at geologiliguria.it
> Posta certificata: gpaliaga at epap.sicurezzapostale.it
> www.edizioniilpiviere.com
> www.guidopaliaga.com
> Think before you print: Rispetta l'ambiente: se non ti è necessario, non
> stampare questa mail.
> Le informazioni contenute nella presente comunicazione e i relativi allegati
> possono essere riservate e sono, comunque, destinate esclusivamente alle
> persone o alla Società sopraindicati. La diffusione, distribuzione e/o
> copiatura del documento trasmesso da parte di qualsiasi soggetto diverso dal
> destinatario è proibita, sia ai sensi dell’art. 616 c.p. , che ai sensi del
> D.Lgs. n. 196/2003. Se avete ricevuto questo messaggio per errore, vi
> preghiamo di distruggerlo e di informarci immediatamente  inviando un
> messaggio all’indirizzo e-mail gpaliaga at gmail.com
