[Qgis-user] How to open ESRI geodatabase in QGIS 1.8 and Gdal 1.9 on Ubuntu?
Peter Schürch p.schuerch at meierpartner.ch
Wed Nov 7 04:43:20 PST 2012
I think I managed to open ESRI Geodatabase as a Database source without any tweaking opening them as a Vectorfile and then choosing Database (instead of File).
Peter
QGis 1.8, Windows 7
Meier und Partner AG, Switzerland, www.meierpartner.ch
Von: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] Im Auftrag von Johan Nilsson
Gesendet: Mittwoch, 7. November 2012 13:07
An: qgis-user
Betreff: Re: [Qgis-user] How to open ESRI geodatabase in QGIS 1.8 and Gdal 1.9 on Ubuntu?
Thanx. Downloadig the FileGDB_API_1_2-32.tar.gz and also the 64-bit version.
I have only compiled one thing in Ubuntu and that was a component in Unity (to get navigation buttom, to the left in stead of right, and during that I have a row, to row tutorial.
Can this help me?
https://github.com/usgin/ncgmp/wiki/Installation-Example
Thanx for al tips and helps /Cheers
2012/11/7 Alex Mandel <tech_dev at wildintellect.com>
On 11/06/2012 10:43 PM, Johan Nilsson wrote:
> How do I open ESRIs geodatabase .gdb-files in QGIS 1.8 and Gdal 1.9? I have
> found on internet that the package OSGeo4W are needed, but this is only för
> ms-windows, i suppose, but I run Ubuntu 12.04LTS. As I understand it, is
> should also only bee possible for ArcGIS 10, not older versions of ArcGIS.
> By the way, .gdb appears in Ubuntu as a folder with lot of files inside.
> /Cheers Jjohan N
They can be opened on either Windows or Linux, what you need is the
gdal/ogr file geodatabase driver. This requires getting some files from
ESRI (free) and doing a little bit of compiling.
I found this which should help. But I though there was a way that didn't
require a complete gdal compile.
http://www.paolocorti.net/2012/01/10/gdal_19_released/
As for ArcGIS, there are several versions of Geodatabases, newer Arcs
can read older databases but not vice versa.
Thanks,
Alex
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121107/153df753/attachment.html>
