[Qgis-user] Defining action to update fields while editing?
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Sun Nov 11 14:14:38 PST 2012
i'm searching for a solution for updating field values easily while
editing the layer.
I have a layer consisting of polygons which represent areas with a certain
base value.
Those values multiplied with the polygons area give a result value for the
area which is interesting for us.
We have to "remodel" the polygons (topological editing) to reach
approximately some certain result values.
It would be very nice to be able to have the polygon values be
recalculated on each save action, so we can easily see the results without
having to go to the attribute table, open field calculator, select all
polygons, recalculate the result values from the $area and the base value
manually. This is quite time consuming and really boring after a while.
I thought that there might be a way through the actions tab, but
unfortunately i have really no clue what to do there and basic
informations are really rare or only towards presenting html stuff or
sending values to other programs but not about editing fields in a layer
(at least i didn't find any).
I also know, that in spatialite, there is a possibility to have triggers
to do such things, but those introductions are even more unexisting and
mysterious.
I would prefer (not personally) a way for shape files, cause the people
i'm doing this for possibly think spatialite and such things are
witchcraft or worse.
So, has anyone an idea for an action (if possible at all), or an easy
explanation for some trigger stuff?
Thanx
bernd
Bernd Vogelgesang * Siedlerstrasse 2 * 91083 Baiersdorf * +49-9133-825374
