[Qgis-user] Problem installing Profile plugin
Etienne Tourigny
etourigny.dev at gmail.com
Mon Nov 12 13:47:01 PST 2012
On Mon, Nov 12, 2012 at 7:18 PM, Pedro Venâncio
<pedrongvenancio at yahoo.com> wrote:
> Hi Etienne,
>>> Does this happen just with a 2-point polyline (when initially created)? How about if you first create (and save) a 3-point polyline before using the plugin?
> It's the same, the plugin can not create the profile for the last segment of a polyline (if the polyline has only one segment, then it creates nothing).
I tested with polylines from external files, not with polylines
created by qgis, not sure where the problem lies.
> Should I fill the tickets in http://hub.qgis.org/projects/profiletool/issues ?
yes, sorry I didn't specify
> Thanks!
> Regards,
> Pedro
> ----- Original Message -----
> From: Etienne Tourigny
> On Sun, Nov 11, 2012 at 7:54 PM, Pedro Venâncio
>> Hi Etienne,
>> I'm also having some problems with the Profile Plugin. I'm using Linux (Xubuntu) and QGIS master.
>> The first problem is this with matplotlib (I'm also using matplotlib 1.1.1~rc1):
>> Traceback (most recent call last):
>> File "/home/pedro/.qgis//python/plugins/profiletool/profileplugin.py", line 278, in changePlotLibrary
>> self.wdg.addPlotWidget(self.plotlibrary)
>> File "/home/pedro/.qgis//python/plugins/profiletool/ui/ui_ptdockwidget.py", line 143, in addPlotWidget
>> self.plotWdg = PlottingTool().changePlotWidget("Matplotlib", self.frame_for_plot)
>> File "/home/pedro/.qgis//python/plugins/profiletool/tools/plottingtool.py", line 82, in changePlotWidget
>> fig = Figure( (1.0, 1.0), linewidth=0.0, subplotpars = figure.SubplotParams(left=0, bottom=0, right=1, top=1, wspace=0, hspace=0) )
>> NameError: global name 'figure' is not defined
> I think this is due to major differences between 1.0 and 1.1 - I'll
> try to look into this and probably just disable the matplotlib version
> unless it's 1.0.
> Unless someone has a fix for this...
>> Using Qwt5 it works, but with some problems.
>> On one hand, if I close the Profile Plugin before closing QGIS, the button in Plugins toolbar remains "clicked", and when closing QGIS, it shows this error:
>> Error while unloading plugin profiletool
>> File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 237, in unloadPlugin
>> plugins[packageName].unload()
>> File "/home/pedro/.qgis//python/plugins/profiletool/profileplugin.py", line 80, in unload
>> self.wdg.close()
>> RuntimeError: underlying C/C++ object has been deleted
> probably a problem in plugin unloading. Please file a bug report.
>> In use, the Plugin displays a strange behavior.
>> Using the Selection "Temporary polyline" option, everything works fine.
>> However, with the Selection "Selected polyline" option, if the polyline has only 2 points (start and end), it does not create the profile. If I add another point, the Plugin only creates the profile for the first segment. If I create a fourth point, it just creates a profile for the first and second segments. And so on.
> Please file another bug report for this issue.
>> I leave a screencast showing these problems: http://goo.gl/0tMwk
>> Thanks!
>> Best regards,
>> Pedro Venâncio
