[Qgis-user] QGis noobie needs help with importing Geotaging photos
Johan Nilsson joni8135 at gmail.com
Sat Nov 17 02:33:50 PST 2012
photo2shape are a name for a plugin.
I have had success with photo2shape. The photo appears as point-shapes and
with attribute:
filepath, filename, longitude, latitude, altitude, north (empty), direction
(empty), ps_dat, img_date.
I have not find how I will activate and let an application open the photo
if i click on it, but with the filepath ans filename it should not be a
problem, I think.
Cheers
2012/11/17 Micha Silver <micha at arava.co.il>
>  On 11/17/2012 04:08 AM, h wrote:
> Hi,
> I'm a bit of a noobie to QGis, so please be gentle when explaining the
> obvious!!
> I am wanting to display geotagged photos in QGis (1.8.0-Lisboa running
> on Open Suse)
> I have found the web site:
> 	http://hub.qgis.org/projects/geotagphotos/wiki
> but cannot get the plugin to appear in the plugins / Fetch Python
> Plugins dialog box.
> What is the plugin called?
> What repository is it in?
> Is it still available from a repository?
> Can someone please step me through the process of installing software /
> plugins to import geotagged photos into QGis?
> The plugin was called photo2shape. I also didn't have much success with
> it, so instead I do the following, manually:
> I use exiftool to grab the required tags from the photos. At least
> GPSLatitude, GPSLongitude, and Filename. I run this in a loop to create a
> comma separated text file with each photo represented by one line.
> Now I use the Delimited Text plugin to create a point shapefile of the
> photo locations. In the attribute table I will have the actual filename of
> each photo.
> Next define an Action on this new shapefile (Layer properties
> windows->Action tab) which will open the photo in your image viewer. You
> can see detailed instructions on setting up an action in the QGIS
> documentation:
> http://docs.qgis.org/html/en/user_manual/working_with_vector/vector_properties.html#actions-tab
> The action will be composed of the viewer binary + full path to the photo.
> After getting that setup, a right click on each point will bring the info
> windows with the option to run the action.
> HTH,
> Micha
> (I use the exif for my own qt applications, so am reasonable
> familiar with it.  It is the qgis python bit that eludes me!)
> With thanks,
> H
> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
> This mail was received via Mail-SeCure System.
> Micha Silver
> GIS Consultant, Arava Development Co.http://www.surfaces.co.il
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121117/f4157ea9/attachment.html>
