[Qgis-user] How to compile gdal with ESRI FileGDB
Eric Goddard
egoddard1010 at gmail.com
Sun Nov 18 20:13:44 PST 2012
I think you're right about ld. You need to run sudo ldconfig after creating
the symlink so that make can find the correctly named library.
Eric
On Sun, Nov 18, 2012 at 7:49 AM, Johan Nilsson <joni8135 at gmail.com> wrote:
> Hey. I have had a lot of things to do, but now I tried to make a sample
> again. I also made a ln -s *libfgdblinuxrtl.so **libfgdbunixrtl.so* (ESRI
> changed the name of the driver) I tried again and still stuck on make in
> samples, as in above and a very simulare error. I have build-essential with
> a lot of depends...
> joni at Intel:~/Desktop/gdal-mod/FileGDB_API/samples$ make
> make -C Domains
> make[1]: Entering directory
> `/home/joni/Desktop/gdal-mod/FileGDB_API/samples/Domains'
> g++ -fPIC -O3 -m32 -W -fexceptions -D_CONSOLE -DUNICODE -D_UNICODE -DUNIX
> -D_REENTRANT -DFILEGDB_API -D__USE_FILE_OFFSET64 -DUNIX_FILEGDB_API
> -D_FILE_OFFSET_BITS=64 -D_LARGEFILE64_SOURCE -I../../include -I. -c
> Domains.cpp
> -D_FILE_OFFSET_BITS=64 -D_LARGEFILE64_SOURCE -I../../include -I. -m32
> -L"../../lib" -o ../bin/Domains ./Domains.o -lFileGDBAPI
> */usr/bin/ld: warning: libfgdbunixrtl.so, needed by
> ../../lib/libFileGDBAPI.so, not found (try using -rpath or -rpath-link)*
> ../../lib/libFileGDBAPI.so: undefined reference to
> `SysAllocStringByteLen(char*, unsigned int)'
> `VarDateFromStr(wchar_t*, unsigned long, unsigned long, double*)'
> ../../lib/libFileGDBAPI.so: undefined reference to `IID_IGeometry'
> .*.A lot of undefined references...* <--my comments
> `PathFileExistsW(wchar_t const*)'
> `PathFindExtensionW(wchar_t const*)'
> collect2: ld returned 1 exit status
> make[1]: *** [../bin/Domains] Error 1
> make[1]: Leaving directory
> make: *** [Domains] Error 2
> I wonder if I need to change anything in linux dynamic linker (*ld*)?
> 2012/11/15 Eric Goddard <egoddard1010 at gmail.com>
>> Hmmm, I didn't get any errors like that when I installed so I'm not sure
>> what could be causing it. Do you have the build-essential package installed
>> that provides the necessary compile tools?
>> On Thu, Nov 15, 2012 at 3:14 AM, Johan Nilsson <joni8135 at gmail.com>wrote:
>>> Thanks very much Eric :)
>>> I have read the instuctions, and
>>> tar zxvf FileGDB_API_1_2-32.tar.gz went well but I'm stuck on point 4
>>> in the fist part of you instruction to make a sample to test the driver:
>>> It spot out a lot of thing complaining about 'undefiened reference
>>> to'... and it ends like:
>>> `/home/a/Desktop/gdal-mod/FileGDB_API/samples/Domains'
>>> Joni at Intel:~/Desktop/gdal-mod/FileGDB_API/samples$
>>> I tried to ignore the errors above, but when I move to *bin* it was
>>> empty and nothing happend:
>>> ~/Desktop/gdal-mod/FileGDB_API/samples/bin$ ./Querying
>>> bash: ./Querying: No such file or directory
>>> I checked with ls -all and *bin* was empty.
>>> Cheers and thanks
>>> /Johan
>>> 2012/11/14 Eric Goddard <egoddard1010 at gmail.com>
>>>> Below are the steps I use to add File Geodatabase support to gdal. This
>>>> worked on Ubuntu 12.04 64-bit, but it doesn't use the deb source packages.
>>>> Since you have a 32-bit ubuntu install, you need to download the 32-bit
>>>> version of the FileGDB API. I tried to answer your questions as they come
>>>> up in the steps I list below, so you may want to read through the whole
>>>> thing before starting. Sorry for the length, but I hope it helps!
>>>> In terminal:
>>>> 1. Change directory to wherever you downloaded the FileGDBAPI: *cd
>>>> path/to/FileGDBAPI_download*
>>>> 2. extract the archive:* tar zxvf FileGDB_API_1_2-32.tar.gz* NOTE:
>>>> Since you are using 32-bit Ubuntu, you need to download the 32-bit FileGDB
>>>> API.
>>>> 3.You need to build the samples to make sure the API works. Change to
>>>> the FileGDB_API samples folder: *cd FileGDB_API/samples*
>>>> 4. type *make*
>>>> 5. Run a sample to make sure it works. Change directory to the bin
>>>> folder inside samples: *cd bin *, and then type *./Querying*. You'll
>>>> get a bunch of text in terminal, just make sure it doesn't spit out any
>>>> errors.
>>>> 6. If the sample runs successfully, you have a working FileGDB API and
>>>> you are ready to compile GDAL. I like to move the FileGDB API to a better
>>>> location than the downloads directory, but it is up to you. If you choose
>>>> to move it, you can use the paths listed below. If you use your own
>>>> location, change the path in the commands below to whatever you used. *sudo
>>>> mv <your location>/FileGDB_API /usr/local/*
>>>> 7. Create a LD configuration file so that gdal is able to find the FGDB
>>>> libraries: *sudo echo /usr/local/FileGDB_API/lib >
>>>> etc/ld.so.conf.d/fgdb.conf *
>>>> An explanation of ld is below.
>>>> 8. run ldconfig to update the linked libraries: *sudo ldconfig*
>>>> You're now ready to download and configure gdal.
>>>> 1. Download gdal from http://download.osgeo.org/gdal/gdal-1.9.2.tar.gz
>>>> 2. Extract the contents of the gdal archive: *tar zxvf
>>>> gdal-1.9.2.tar.gz*
>>>> 3. Change to the gdal directory: *cd gdal-1.9.2*
>>>> 4. Now gdal needs to be configured. Your configure line may be
>>>> different from the one below depending on the options you want included,
>>>> but the important line to include is --with-fgdb=/usr/local/FileGDB_API.
>>>> This is my configure line on my system: * ./configure --with-geos=yes
>>>> --with-sqlite3 --with-python --with-spatialite
>>>> --with-fgdb=/usr/local/FileGDB_API --with-postgres --with-odbc
>>>> --with-libkml=yes --with-curl=yes
>>>> --with-mrsid=/usr/local/MrSID_SDK/Raster_DSDK
>>>> --with-mrsid_lidar=/usr/local/MrSID_SDK/Lidar_DSDK
>>>> --with-openjpeg=/usr/include*
>>>> The --with statements let the configuration script know what additional
>>>> modules you want to be included in the compile. When you install packages,
>>>> such as geos, from the repos the libraries are put in paths that ld (which
>>>> is a utility that links libraries so that other applications are able to
>>>> find them) knows about. When you compile by hand the general practice is to
>>>> compile to /usr/local, which sometimes ld doesn't know about by default.
>>>> You let ld know about additional paths by creating a configuration file in
>>>> /etc/ld.so.conf.d/ that contains the path of your custom compiled
>>>> libraries.
>>>> To compile GDAL with the options you want, your line might look
>>>> something like this:
>>>> *./configure --with-geos=yes --with-sqlite3 --with-python
>>>> --with-spatialite --with-fgdb=/usr/local/FileGDB_API --with-postgres
>>>> --with-odbc *
>>>> After configure runs, it will give you a summary that indicates what it
>>>> was able to find. Check to make sure that there is a 'yes' beside the
>>>> options you want. If there is a no beside something you want to include,
>>>> you may need to scroll through the output and find the error to see what
>>>> went wrong.
>>>> 5. Now you can run make and make install. *sudo make*. When that
>>>> finishes, run *sudo make install*.
>>>> 6. One more step: you need to let ld know about the gdal libraries.
>>>> Since we didn't specify a different path, the configure line above puts
>>>> them in /usr/local/lib by default. I let ld know about the libraries by
>>>> adding a local.conf file to /etc/ld.so.conf.d/. *sudo echo
>>>> /usr/local/lib > /etc/ld.so.conf.d/local.conf*
>>>> 7. Run ldconfig again: *sudo ldconfig*
>>>> You should be able to open geodatabases in QGIS or any other GIS
>>>> application that uses GDAL now. I expanded on notes that I took while doing
>>>> the install, but I didn't have my linux laptop with me while writing this.
>>>> Let me know if anything doesn't work or if clarification is needed.
>>>> On Nov 13, 2012 9:27 AM, "Johan Nilsson" <joni8135 at gmail.com> wrote:
>>>>> I have tried to find how I compile gdal 1.9.2 with ESRIs FileGDB_API,
>>>>> but I'm are very uncertain how it work. I have Ubuntu 10.04LTS 32-bit
>>>>> with PAE. I another step I downloaded source-code for gdal-1.9.2 and added
>>>>> needed packed with:
>>>>> *cd ~/Desktop/gdal-mod* <--move cursor to the created folder.
>>>>> *apt-get source gdal-bin *<--download source-cod from my
>>>>> respositories (same as my binary installed on my system, into the folder I
>>>>> stand in ~/Desktop/gdal-mod)
>>>>> *sudo apt-get build-dep gdal* <--geting dependencies so my system can
>>>>> build the package gdal.
>>>>> From https://github.com/usgin/ncgmp/wiki/Installation-Example I
>>>>> found this example
>>>>> 1.
>>>>> *cd ~/downloads *<--change to the folder with the downloaded
>>>>> driver from ESRI*
>>>>> 2.
>>>>> *tar xzf FileGDB_API_1_2-64.tar.gz *<--unpacking
>>>>> 3.
>>>>> *cd ~/downloads/FileGDB_API/lib *<--goes to a file in the unpacked
>>>>> FileGDB*
>>>>> 4.
>>>>> *ln -s libfgdbunixrtl.so libfgdblinuxrtl.so <--made a symbolic
>>>>> link in the folder lib because ESRI change the name.*
>>>>> 5.
>>>>> *cd ../..* <--up 2 levels*
>>>>> 6.
>>>>> *tar xvf gdal-1.9.0.tar.gz *<--unpacking, I have a newer file*
>>>>> 7.
>>>>> *cd gdal-1.9.0 *
>>>>> 8.
>>>>> *./configure --with-pg=/usr/bin/pg_config
>>>>> --with-fgdb=/home/ubuntu/downloads/FileGDB_API
>>>>> --with-geos=/usr/local/bin/geos-config
>>>>> --with-static-proj4=/usr/local/lib/libproj.a --with-python *
>>>>> 9.
>>>>> *make *
>>>>> 10.
>>>>> *sudo make install*
>>>>> First a question! If I make a 'make install', and if it don't work,
>>>>> how can i change back to my original gdal-bin?
>>>>> Second. Does this install libFileGDBAPI.so (Read a tutorial, there they
>>>>> said that libFileGDBAPI.so should be install in it default directory,
>>>>> which I don't know where it is...
>>>>> 6. I have a newer version of gdal (1.9.2) and I have the 32-bit
>>>>> version on this machine. The swift '--with' in this example above are not
>>>>> so accurate for my system, I think? What does '--with' really do? Does it
>>>>> create links in gdal or does it more?
>>>>> Does someone know which swift '--with ' I should have or are necessaryor good to have? Do the FileGDB also get compiled at the same time?
>>>>> I seach my system and change the path in the example: first where I
>>>>> have my FileGDB_API and then some other files have also a different
>>>>> path? Do I need all this --with, or does a default file add it?
>>>>> My modified '--with', if it's needed?
>>>>> --with-fgdb=/home/Joni/Desktop/gdal-mod/FileGDB_API
>>>>> --with-geos=/usr/bin/geos-config
>>>>> --with-static-proj4=/usr/lib/libproj.a --with-python
>>>>> If I don't add anything more than, my FilGDB_API, there the
>>>>> source-code are, does there are any 'Default setting', so It work as now? I
>>>>> had a Postgis config-file as in the example. In this example they had
>>>>> compiled a geos package, but my system did have libgeos and a geos-config
>>>>> file in above blue directory. The '*--with-static-proj4=/usr/
>>>>> local/lib/libproj.a**' *have I changed to another *path*, there I
>>>>> find a* **libproj.a** *file.
>>>>> Hope someone can explain little..
>>>>> /Cheers
>>>>> Johan
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121118/fd66075b/attachment.html>
