[Qgis-user] Fwd: Re: QGISWebserver and PostGIS-Layer
Albin Blaschka
albin.blaschka at standortsanalyse.net
Fri Nov 23 00:36:45 PST 2012
[sorry, forgot the list...]
-------- Original-Nachricht --------
Betreff: Re: [Qgis-user] QGISWebserver and PostGIS-Layer
Datum: Fri, 23 Nov 2012 09:32:03 +0100
Von: Albin Blaschka <albin.blaschka at standortsanalyse.net>
Antwort an: albin.blaschka at standortsanalyse.net
An: Bernhard Ströbl <bernhard.stroebl at jena.de>
Hi!
Am 23.11.2012 09:11, schrieb Bernhard Ströbl:
> Hi,
> do you get a map (and no white image) in QGIS desktop? If yes
> 1) your server is ok but your request is somehow wrong.
> 2) Check your access log and look at the GetMap-request that QGIS
> desktop sends. Compare it to your request.
> If no there is something misconfigured, e.g. the SRS of the layer does
> not match the SRS of the data, the database is not accessible from the
> server (check pg_hba.conf)....
Thank you for your patience!
1.) The map in QGIS Desktop is ok, no problems there! So, yes, the error
lies somewhere with my request.
2.) I just checked the PostgreSQL-log (PostgreSQL is running on the same
machine as Apache and is ok): There I found something strange and most
probably the cause for the error: Each time, I make a request via the
Mapserver, I get the error "column 'geom' does not exist" BUT in the
respective table, the geometry column is called "the_geom" and
registered with this name in the geometry_columns-table (I just chekced
that, too). In the qgs-file (the project file), it is also the_geom -
here the relevant part of the qgs-file:
<projectlayers layercount="1">
<maplayer minimumScale="0" maximumScale="1e+08" geometry="Point"
type="vector" hasScaleBasedVisibilityFlag="0">
<id>verortung20121123083448551</id>
<datasource>dbname='mydatabase' host=myserver port=5432
user='myuser' password='pwd' sslmode=allow key='gid' srid=4326
type=POINT table="myschema"."verortung" (the_geom) sql=</datasource>
I am "slightly" puzzled about that, I just start looking into that issue...
Mhmmm...
Thanks,
best regards,
Albin
> Bernhard
> Am 23.11.2012 08:52, schrieb Albin Blaschka:
>> Hi!
>> Am 23.11.2012 08:02, schrieb Bernhard Ströbl:
>>> Hi Albin,
>>> try
>>> http://myserver/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&FORMAT=image/png&CRS=EPSG:4326&WIDTH=500&HEIGHT=500&LAYERS=mypostgislayer&BBOX=12.96,47.79,12.98,47.81
>>> as a major change from 1.1.1 to 1.3.0 is the exchange of x and y
>>> coordinates or use VERSION=1.3.0 and exchange x and y coordinates of the
>>> BBOX
>>> if I understand you correctly you get an image as reply but the image is
>>> all white. So the server is running ok but there are no data in the
>>> place for which you request the map.
>> Yes, you understand correctly - I followed your example, but no
>> success...
>> Is there a possibility to switch on some kind of logging, additionally
>> to the apache logging? In the apache logs, no errors or warnings or
>> similar appear...
>> Thank you for your help!
>> regards, Albin
>>> Am 22.11.2012 17:05, schrieb Albin Blaschka:
>>>> Hello!
>>>> Thank you for your answer!
>>>>> the URL seems to lack the BBOX parameter (I think this is a necessary
>>>>> parameter in a GetMap request)
>>>>> Can you access the maps through QGIS desktop?
>>>>> What happens if you send a GetCapabilities request:
>>>>> http://myserver/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
>>>> In QGIS Desktop, everything seems ok, the GetCapabilities-Request looks
>>>> also ok - here the head of the answer cut 'n copied:
>>>> <WMS_Capabilities version="1.3.0"
>>>> xsi:schemaLocation="http://www.opengis.net/wms
>>>> http://schemas.opengis.net/wms/1.3.0/capabilities_1_3_0.xsd"><Service><Name>WMS</Name><Title>QGIS-Server</Title><Abstract/><OnlineResource
>>>> xlink:type="simple"
>>>> xlink:href=""/><ContactInformation><ContactPersonPrimary><ContactPerson>Albin
>>>> Blaschka</ContactPerson><ContactOrganization>LFZ
>>>> Raumberg-Gumpenstein</ContactOrganization></ContactPersonPrimary><ContactVoiceTelephone/><ContactElectronicMailAddress>albin.blaschka at raumberg-gumpenstein.at</ContactElectronicMailAddress></ContactInformation></Service>
>>>> Concerning the BBOX:
>>>> I tried it with the following URL (for a small area close to the
>>>> town of
>>>> Salzburg), but again, no success, just a white canvas:
>>>> http://myserver/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&FORMAT=image/png&CRS=EPSG:4326&WIDTH=500&HEIGHT=500&LAYERS=mypostgislayer&BBOX=12.96,47.79,12.98,47.81
>>>> Thanks,
>>>> Albin
>>>>> Bernhard
>>>>> Am 22.11.2012 16:12, schrieb Albin Blaschka:
>>>>>> Hello!
>>>>>> I just started to use QGIS Server on an Ubuntu server, after
>>>>>> installation and basic configuration, I get a successful answer of a
>>>>>> GetCapability-Request.
>>>>>> Now, for my first "real" project, I have a question regarding the
>>>>>> QGIS
>>>>>> Server and PostGIS-Layers: If I enter the following URL in firefox, I
>>>>>> just get a blank canvas, no layer:
>>>>>> What I have done so far:
>>>>>> * I have set up a project in QGIS Desktop including a PostGIS-Layer,
>>>>>> with the connection storing the full connection string (username and
>>>>>> password), the layer is shown as it should be
>>>>>> * I saved the QGIS project file and opend it in a text editor and
>>>>>> found
>>>>>> the credentials for the PostGIS-Layer
>>>>>> * I copied the project file into the cgi-bin directory, chmod'ed it
>>>>>> even
>>>>>> to 777, just to get it going; trying it with the "map="-parameter was
>>>>>> also not successfull...
>>>>>> * The database server is the same box as the apache (Ubuntu Oneiric
>>>>>> 11.10, PostgreSQL 8.3.8, PostGIS Version 1.3; it is an
>>>>>> intranet-server,
>>>>>> not reachable from outside)
>>>>>> What have I done wrong?
>>>>>> Thanks in advance,
>>>>>> best regards,
>>>>>> Albin
>>>>> __________ Information from ESET Mail Security, version of virus
>>>>> signature database 7720 (20121122) __________
>>>>> The message was checked by ESET Mail Security.
>>>>> http://www.eset.com
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> signature database 7722 (20121122) __________
> http://www.eset.com
| Albin Blaschka, Mag.rer.nat.
| Etrichstrasse 26, A-5020 Salzburg
| * www.albinblaschka.info * www.thinkanimal.info *
| - It's hard to live in the mountains, hard but not hopeless!
