[Qgis-user] QGISWebserver and PostGIS-Layer
Bernhard Ströbl bernhard.stroebl at jena.de
Fri Nov 23 00:40:24 PST 2012
Hi Albin,
be sure you reply to the list.
It seems that QGIS desktop does not access the same server/same
project/same layer as your request. Check the apache access.log and the
GetMap request issued by QGIS desktop to find any differences.
Bernhard
Am 23.11.2012 09:32, schrieb Albin Blaschka:
> Hi!
> Am 23.11.2012 09:11, schrieb Bernhard Ströbl:
>> Hi,
>> do you get a map (and no white image) in QGIS desktop? If yes
>> 1) your server is ok but your request is somehow wrong.
>> 2) Check your access log and look at the GetMap-request that QGIS
>> desktop sends. Compare it to your request.
>> If no there is something misconfigured, e.g. the SRS of the layer does
>> not match the SRS of the data, the database is not accessible from the
>> server (check pg_hba.conf)....
> Thank you for your patience!
> 1.) The map in QGIS Desktop is ok, no problems there! So, yes, the error
> lies somewhere with my request.
> 2.) I just checked the PostgreSQL-log (PostgreSQL is running on the same
> machine as Apache and is ok): There I found something strange and most
> probably the cause for the error: Each time, I make a request via the
> Mapserver, I get the error "column 'geom' does not exist" BUT in the
> respective table, the geometry column is called "the_geom" and
> registered with this name in the geometry_columns-table (I just chekced
> that, too). In the qgs-file (the project file), it is also the_geom -
> here the relevant part of the qgs-file:
> <projectlayers layercount="1">
> <maplayer minimumScale="0" maximumScale="1e+08" geometry="Point"
> type="vector" hasScaleBasedVisibilityFlag="0">
> <id>verortung20121123083448551</id>
> <datasource>dbname='mydatabase' host=myserver port=5432 user='myuser'
> password='pwd' sslmode=allow key='gid' srid=4326 type=POINT
> table="myschema"."verortung" (the_geom) sql=</datasource>
> I am "slightly" puzzled about that, I just start looking into that issue...
> Mhmmm...
> Thanks,
> best regards,
> Albin
>> Bernhard
>> Am 23.11.2012 08:52, schrieb Albin Blaschka:
>>> Hi!
>>> Am 23.11.2012 08:02, schrieb Bernhard Ströbl:
>>>> Hi Albin,
>>>> try
>>>> http://myserver/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&FORMAT=image/png&CRS=EPSG:4326&WIDTH=500&HEIGHT=500&LAYERS=mypostgislayer&BBOX=12.96,47.79,12.98,47.81
>>>> as a major change from 1.1.1 to 1.3.0 is the exchange of x and y
>>>> coordinates or use VERSION=1.3.0 and exchange x and y coordinates of
>>>> the
>>>> BBOX
>>>> if I understand you correctly you get an image as reply but the
>>>> image is
>>>> all white. So the server is running ok but there are no data in the
>>>> place for which you request the map.
>>> Yes, you understand correctly - I followed your example, but no
>>> success...
>>> Is there a possibility to switch on some kind of logging, additionally
>>> to the apache logging? In the apache logs, no errors or warnings or
>>> similar appear...
>>> Thank you for your help!
>>> regards, Albin
>>>> Am 22.11.2012 17:05, schrieb Albin Blaschka:
>>>>> Hello!
>>>>> Thank you for your answer!
>>>>>> the URL seems to lack the BBOX parameter (I think this is a necessary
>>>>>> parameter in a GetMap request)
>>>>>> Can you access the maps through QGIS desktop?
>>>>>> What happens if you send a GetCapabilities request:
>>>>>> http://myserver/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
>>>>> In QGIS Desktop, everything seems ok, the GetCapabilities-Request
>>>>> looks
>>>>> also ok - here the head of the answer cut 'n copied:
>>>>> <WMS_Capabilities version="1.3.0"
>>>>> xsi:schemaLocation="http://www.opengis.net/wms
>>>>> http://schemas.opengis.net/wms/1.3.0/capabilities_1_3_0.xsd"><Service><Name>WMS</Name><Title>QGIS-Server</Title><Abstract/><OnlineResource
>>>>> xlink:type="simple"
>>>>> xlink:href=""/><ContactInformation><ContactPersonPrimary><ContactPerson>Albin
>>>>> Blaschka</ContactPerson><ContactOrganization>LFZ
>>>>> Raumberg-Gumpenstein</ContactOrganization></ContactPersonPrimary><ContactVoiceTelephone/><ContactElectronicMailAddress>albin.blaschka at raumberg-gumpenstein.at</ContactElectronicMailAddress></ContactInformation></Service>
>>>>> Concerning the BBOX:
>>>>> I tried it with the following URL (for a small area close to the
>>>>> town of
>>>>> Salzburg), but again, no success, just a white canvas:
>>>>> http://myserver/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&FORMAT=image/png&CRS=EPSG:4326&WIDTH=500&HEIGHT=500&LAYERS=mypostgislayer&BBOX=12.96,47.79,12.98,47.81
>>>>> Thanks,
>>>>> Albin
>>>>>> Bernhard
>>>>>> Am 22.11.2012 16:12, schrieb Albin Blaschka:
>>>>>>> Hello!
>>>>>>> I just started to use QGIS Server on an Ubuntu server, after
>>>>>>> installation and basic configuration, I get a successful answer of a
>>>>>>> GetCapability-Request.
>>>>>>> Now, for my first "real" project, I have a question regarding the
>>>>>>> QGIS
>>>>>>> Server and PostGIS-Layers: If I enter the following URL in
>>>>>>> firefox, I
>>>>>>> just get a blank canvas, no layer:
>>>>>>> What I have done so far:
>>>>>>> * I have set up a project in QGIS Desktop including a PostGIS-Layer,
>>>>>>> with the connection storing the full connection string (username and
>>>>>>> password), the layer is shown as it should be
>>>>>>> * I saved the QGIS project file and opend it in a text editor and
>>>>>>> found
>>>>>>> the credentials for the PostGIS-Layer
>>>>>>> * I copied the project file into the cgi-bin directory, chmod'ed it
>>>>>>> even
>>>>>>> to 777, just to get it going; trying it with the "map="-parameter
>>>>>>> was
>>>>>>> also not successfull...
>>>>>>> * The database server is the same box as the apache (Ubuntu Oneiric
>>>>>>> 11.10, PostgreSQL 8.3.8, PostGIS Version 1.3; it is an
>>>>>>> intranet-server,
>>>>>>> not reachable from outside)
>>>>>>> What have I done wrong?
>>>>>>> Thanks in advance,
>>>>>>> best regards,
>>>>>>> Albin
>>>>>> __________ Information from ESET Mail Security, version of virus
>>>>>> signature database 7720 (20121122) __________
>>>>>> The message was checked by ESET Mail Security.
>>>>>> http://www.eset.com
>>>>>> _______________________________________________
>>>>>> Qgis-user mailing list
>>>>>> Qgis-user at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
__________ Information from ESET Mail Security, version of virus signature database 7722 (20121122) __________
http://www.eset.com
