[Qgis-user] error when installing new plugin
haubourg regis.haubourg at eau-adour-garonne.fr
Wed Nov 28 07:36:52 PST 2012
not sure if it helps, --configpath option could be a temporary workaround
(see manual, this allows to move profile in other location than default
%user% directory) .
To use it in windows, a simple way is to modify the shortcut icon of qgis.
Add the following after the commandline finishing by "../qgis.bat"
--configpath "W:/myfolder/".
take care of backslashes vs slashes, on Windows: see
http://hub.qgis.org/issues/6764#change-37330
restart and install a plugin with the installer. Check that W:/myfolder/ now
contains .qgis/ . If you get error messaging on plugin install, then you
used \ instead of /..
Please tell us if it works
View this message in context: http://osgeo-org.1560.n6.nabble.com/error-when-installing-new-plugin-tp5018963p5019332.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
