[Qgis-user] How to generate (vector)contour lines for point data?
M.E.Dodd
m.e.dodd at open.ac.uk
Mon Oct 1 07:32:19 PDT 2012
Is it possible to define an area to do the surface generation within? I see there are options to define this with a simple box or drag on screen but if you want to say use a country outline map as the boundary and do the interpolation within this?
-----Original Message-----
Sent: 01 October 2012 14:16
To: AJAY KUMAR MULAKALA
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] How to generate (vector)contour lines for point data?
On 10/01/2012 06:50 AM, AJAY KUMAR MULAKALA wrote:
> Dear sir,
> Suggest me how to generate contour lines for a point data (particular
> to generate contour lines about an attribute information of point
> data)
You will need two steps. First use the points to create a raster surface. In the Raster menu, choose Analysis->Grid. With this GDAL tool you can create a raster using some simple algorithms. THen using this new raster as your surface, use the GDAL tool
Raster->Extraction->Contour to get vector contour lines.
(Note that if you switch to the GRASS plugin, there are more interpolation algorithms available, especially "regularized spline"=rst, for creating the surface raster)
Regards,
Micha
> Regards,
> AJAY KUMAR
> This mail was received via Mail-SeCure System.
> Qgis-user mailing list
Micha Silver
GIS Consultant, Arava Development Co.
http://www.surfaces.co.il
The Open University is incorporated by Royal Charter (RC 000391), an exempt charity in England & Wales and a charity registered in Scotland (SC 038302).
