[Qgis-user] DXF EXPORT
Andreas Neumann a.neumann at carto.net
Tue Oct 2 08:41:39 PDT 2012
 Are you dealing with Polygon data?
 There was just a recent fix in ogr dxf writing which was fixed
 yesterday:
 trac.osgeo.org/gdal/ticket/4680
 I don't know how often gdal-dev is updated in osgeo4w if you can update
 it yourself.
 It is ogr's fault, not QGIS' fault.
 Andreas
 On Tue, 02 Oct 2012 17:00:31 +0300, Zirneklitis wrote:
> One of the solutions is to used command-line tool ogr2ogr (available
> in Quntum GIS 'bin' directory:
> ogr2ogr  -f "DXF"  result.DXF source.shp
> the_sloth wrote:
>> Ok, I am using Notepad++ now. Line 1548 is 0. Why would this cause a
>> problem?
>> What does this mean?
>> <http://osgeo-org.1560.n6.nabble.com/file/n5004756/dxf_export2.jpg>
> Qgis-user mailing list
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
