[Qgis-user] NViz not starting in QGIS
UserError
jonathan at jwebbgis.co.uk
Thu Oct 4 07:21:52 PDT 2012
Saber wrote
"If installing from OSGeo4W, ensure the tcl/tk library is installed."
How do I do that? I downloaded the OSgeo4W installer & followed the "In the
installer choose Desktop Express Install and select QGIS to install Quantum
GIS." There's nothing to do?
To see if i missed anything I've just done a clean install on another PC
(win 7 64bit), this time I selected the "custom install" & opted to install
everything, to make sure I didn't miss any TCL/TK items. After an age & a
reboot, all I got was an error about ippj-5.3.dll missing, so that hasn't
contributed to the solution.
And also
"Also, could you try and run it under GRASS itself."
I've loaded some data into GRASS & Nviz runs OK, so the problem lies with
the implementation of it from QGis.
Can anyone help please?
Many thanks
Jonathan
On 20/09/2012 09:37, Jonathan Webb wrote:
> Hi,
> I'm exploring QGIS, having used ArcGis & MapInfo for years, but am
> having trouble. PC is Win XP SP3 32bit.
> I'm getting a problem with NVIZ - it won't start, with a message about
> not finding init.tcl etc. There is an amount about this on the web
> but it is either too technical/not clear enough for me, or unresolved.
> One answer was to ensure that TCL was installed through OSGeo4W so I
> uninstalled/deleted as much of QGIS etc as I could find, then run two
> registry cleaners several times before restarting & downloading
> OSGeo4W.exe which also appears to have installed QGIS etc.
> Things looked hopeful when I clicked on the MSys & OSGeo4W links as I
> received no error messages. But I still get the same NVIZ error message.
> Are there any log files I should look for?
> I've looked in nviz2.2_script which appears to be invoked by NViz &
> also one of the init.tcl in various folders, but can't work out
> anything from these.
> Many thanks
> Jonathan
> J Webb GIS 07941 921905
> Qgis-user mailing list
> Qgis-user at .osgeo
This email and any files transmitted with it are confidential and intended
solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager.
This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not
disseminate, distribute or copy this e-mail. Please notify the sender
immediately
by e-mail if you have received this e-mail by mistake and delete this e-mail
from your system. If you are not the intended recipient you are notified
that disclosing, copying, distributing or taking any action in reliance on
the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no
responsibility for viruses is taken and it is your responsibility to carry
out
such checks as you feel appropriate.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
Qgis-user at .osgeo
View this message in context: http://osgeo-org.1560.n6.nabble.com/NViz-not-starting-tp5003177p5006440.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
