[Qgis-user] QGIS-Server: Premature end of script headers: qgis_mapserv.fcgi.exe
Goyo goyodiaz at gmail.com
Fri Oct 5 04:25:44 PDT 2012
I´m facing the same problem. QGis libraries are not in the system path
since the OSGeo4w installer does not change it. OSGeo4w applications
usually are run from a batch script which sets the needed environment
variables.
QGIS bin directory is in the path defined in D:\OSGeo4w\httpd.d\httpd_qgis.conf:
DefaultInitEnv PATH
"D:\OSGeo4w\bin;D:\OSGeo4w\apps\qgis\bin;D:\OSGeo4w\apps\grass\grass-6.4.2\bin;D:\OSGeo4w\apps\grass\grass-6.4.2\lib;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem"
Shouldn't this be enough?
Goyo
2012/10/1 G. Allegri <giohappy at gmail.com>:
> Have you checked that the QGis libraries (qgis_core.dll, etc.) are on your
> system PATH?
> giovanni
> 2012/10/1 Kai Volland <kaivolland at yahoo.de>
>> Hi,
>> i'm trying to install the QGIS-Server on my local machine (win 7) and a
>> testserver. In both cases i get a 500 internal server error: Error-log:
>> "Premature end of script headers: qgis_mapserv.fcgi.exe"
>> I'installed the server following this guide:
>> http://underdark.wordpress.com/2012/04/06/qgis-server-on-windows7-step-by-step/
>> But the GetCapabilities-Request doesn't work.
>> On the local machine i already get a 500 server when looking at
>> http://localhost/qgis/qgis_mapserv.fcgi.exe.
>> Kind regards,
>> Kai
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
