[Qgis-user] "Normal" mdb support possible for "normal" people? (now - mdbtools for Mac OS X and Linux - working)
Noli Sicad nsicad at gmail.com
Wed Oct 10 17:17:09 PDT 2012
On 9/26/12, Even Rouault <even.rouault at mines-paris.org> wrote:
>> I also had problems compiling the old version (at sourceforge), but I
>> think
>> it was something in the CLI tools, which I didn't need for ODBC.  I made
>> a
>> custom makefile to get the ODBC driver, but it never worked.  Maybe I'll
>> try again with the new version (though it's low priority for me, no
>> need).
>> There is a commercial OS X ODBC driver (Actual Tech) that I thought was
>> based on mdbtools, but that can't be right since they don't distribute
>> their source code.  I could not get theirs to works, problem skipping
>> bytes in blobs (which is where the coordinate data is stored), they could
>> not fix it.
> I've just tried with the GIT version of  https://github.com/brianb/mdbtools
> and with UnixODBC 2.3.1.
> Like last time I tried, I got compilation errors to compile odbc.c (the
> implementation of the ODBC driver) from mdbtools due to 64bit
> incompatibilities. I fixed them to the point where it compiles, but the MDB
> ODBC driver still misbehaves.
> However, I tried the mdb-export tool that just uses the libmdb API and it
> seemed to read correctly a Personal Geodatabase MDB (whereas the old version
> that ships with my Ubuntu 10.04 crashes), so it should perhaps be possible
> for
> someone to write a driver that used the libmdb API directly, or alter the
> OGR
> MDB driver to use libmdb instead of Jackess (the Java part of the driver is
> quite isolated, so libmdb and Jackess could be 2 backends used indifferently
> by
> the driver).
I just like to inform the list that mdbtools (library and odbc.c) work
 (compile and install) in Mac OS X now. I have not tested yet.
Posted these 2 issues in github and it is all fixed.
https://github.com/brianb/mdbtools/issues/18
https://github.com/brianb/mdbtools/issues/17
For linux users, please test and report any issues.
Thanks.
Noli
