[Qgis-user] Problems compiling QGIS under OS X 10.8.2
Sasha Cuerda sasha.cuerda at gmail.com
Sat Oct 13 11:12:28 PDT 2012
Hello,
I am having some difficulties compiling QGIS and I'm hoping someone here can help…I have a hunch that the source of this problem is with Python but I'm not very sophisticated when it comes to  application development.
I have installed all required dependencies using a combination of Homebrew and manual installation (adding symbolic links when necessary).
I followed the recommendations of homebrew in regards to SIP and issued the following command prior to initiating the build:
export PYTHONPATH=/usr/local/lib/python2.7/site-packages:$PYTHONPATH
I am trying to use the following command to initiate the build:
cmake -D CMAKE_INSTALL_PREFIX=/volumes/Main/Applications \
-D CMAKE_BUILD_TYPE=MinSizeRel \
-D ENABLE_TESTS=FALSE \
-D WITH_INTERNAL_SPATIALITE=FALSE \
-D WITH_PYSPATIALITE=FALSE \
-D WITH_GRASS=TRUE \
-D GRASS_PREFIX=/usr/local/bin/ \
-D QWT_LIBRARY=/usr/local/Cellar/qwt/6.0.1/lib/qwt.framework \
-D QWT_INCLUDE_DIR=/usr/local/Cellar/qwt/6.0.1/lib/qwt.framework/Headers \
-D SPATIALINDEX_LIBRARY=/usr/local/lib/libspatialindex.dylib \
-D SPATIALINDEX_INCLUDE_DIR=/usr/local/include/spatialindex \
-D BISON_EXECUTABLE=/usr/local/bin/bison \
-D EXPAT_LIBRARY=/usr/local/lib/libexpat.dylib \
-D EXPAT_INCLUDE_DIR=/usr/local/include \
-D GEOS_INCLUDE_DIR=/usr/local/include \
-D GEOS_LIBRARY=/usr/local/lib/libgeos_c.dylib \
-D GDAL_INCLUDE_DIR=/usr/local/include \
-D GDAL_LIBRARY=/usr/local/lib/libgdal.dylib \
-D GSL_INCLUDE_DIR=/usr/local/include \
-D GSL_LIBRARIES=/usr/local/lib/libgsl.dylib \
-D POSTGRES_INCLUDE_DIR=/usr/local/include \
-D POSTGRES_LIBRARY=/usr/local/lib/libpq.dylib \
I get the following output:
-- Quantum GIS version: 1.9.0 Master (10900)
-- Could not find GRASS
-- Found Proj: /Library/Frameworks/PROJ.framework
-- Found GEOS: /usr/local/lib/libgeos_c.dylib
-- Found GDAL: /usr/local/lib/libgdal.dylib (1.9.2)
-- Found Expat: /usr/local/lib/libexpat.dylib
-- Found Spatialindex: /usr/local/lib/libspatialindex.dylib
-- Found Qwt: /usr/local/Cellar/qwt/6.0.1/lib/qwt.framework (6.0.1)
-- Found Sqlite3: /Library/Frameworks/sqlite3.framework
-- Found PostgreSQL: /usr/local/lib/libpq.dylib
-- Touch support disabled
-- Pedantic compiler settings enabled
/usr/local/Cellar/python/2.7.3/Frameworks/Python.framework/Versions/2.7/Resources/Python.app/Contents/MacOS/Python: can't open file '_find_lib_python_py-NOTFOUND': [Errno 2] No such file or directory
-- Found Python executable: /usr/local/bin/python2.7
-- Found Python version:
-- Found Python library: /usr/local/lib/python2.7/
/usr/local/Cellar/python/2.7.3/Frameworks/Python.framework/Versions/2.7/Resources/Python.app/Contents/MacOS/Python: can't open file '_find_sip_py-NOTFOUND': [Errno 2] No such file or directory
CMake Error at cmake/FindSIP.cmake:54 (MESSAGE):
  Could not find SIP
Call Stack (most recent call first):
  CMakeLists.txt:494 (FIND_PACKAGE)
If I run python FindSIP.py from the CMAKE folder, I get this:
sip_version:040e00
sip_version_num:265728
sip_version_str:4.14
sip_bin:/usr/local/Cellar/python/2.7.3/Frameworks/Python.framework/Versions/2.7/bin/sip
default_sip_dir:/usr/local/Cellar/python/2.7.3/Frameworks/Python.framework/Versions/2.7/share/sip
sip_inc_dir:/usr/local/Cellar/python/2.7.3/Frameworks/Python.framework/Versions/2.7/include/python2.7
sip_mod_dir:/usr/local/Cellar/python/2.7.3/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site-packages
Which is what I would expect.
Any idea what is going on here and how to fix it?
Thanks in advance for any help you can provide.
-Sasha
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121013/0eb8b559/attachment.html>
