[Qgis-user] QGIS and MySQL
Sebastiano Lora sebastiano.lora at gmail.com
Wed Oct 17 08:36:04 PDT 2012
Hallo everybody,
I have a some difficulties with QGIS and a MySQL database. I try to make it
not so long, and work enviroment is WIN 7 64b; QGIS dev, MySQL 5.1.63
In my project (a GIS for an archaeological excavation) lot of data are
stored in a MySQL database which was made before I joined it. Originally no
geometry field was inserted in the MySQL tables and thereafter I have many
features without stored geometry. My approach at the beginning was to
create shapefiles (point and polygons mainly) of the features which I
needed and to join them with the MySQL table that I imported into QGIS.
Then now I have
shapefiles
MySQL tables
Both have an ID which allow to join them together.
This worked just fine, but now I want to get rid of this double approach
and use the MySQL database as a complete geodatabase (I know I should
transfer it in postGRE but it is not a short-term possibility). The reasons
are: a) I want to create a webgis of the project; b) since we are now more
persons who are working with  GIS I would like that more than one user
could work on the same shapefile at the same time; c) it is more "elegant".
Now my question is how I merge the spatial information from the shapefiles
into the MySQL tables?
for the point shapefiles it was not a big problem since I had the lat long
coordinates stored in the db, I just create a query which writes them in
the POINT field.
for the polygons is not so easy.
I tried to install the QGIS plugin "export to MySQL" with the idea:
- export the shapefile into MySQL
- update the table with the geometry field
but the plug-in does not work since a module is missing (MySQLdb). There is
already a lot of documentation on it which I read. An installer for is also
available BUT it is not working with my OSGEO installation. It seems that
it is installing the module in a second installation of php that I have and
not in for the php installed by the OSGEO, which is the one that QGIS is
calling. Compiling it by myself is out of my skills.
(of course I could export my shapefile in .csv, import it in MySQL and than
run the query BUT I was looking for something simpler and that I could use
often)
Finally:
somebody who had success in installing the export to Mysql plug-in in one
OSGEO installation could tell me what I should do?
Anybody has some suggestion how to solve my problem?
Thanks in advance
Sebastiano
Sebastiano Lora Dr phil
Deutsches Archäologische Institut Orient-Abteilung
Podbielskiallee 69-71
14195 Berlin, Germany
Tel. +49-30-187711-265
Fax +49-30-187711-189
cell 00491627638459
skype: sebastiano.lora
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121017/910bcbf6/attachment.html>
