[Qgis-user] Using/visualizing 3D data (Z values)
David Fawcett
david.fawcett at gmail.com
Wed Oct 17 09:19:17 PDT 2012
Thank you very much for your help. Indeed, it was the PATH/PYTHONPATH issue.
I think that when I installed QGIS last time, I was in a rush and
didn't think that I would need the Python support. I decided to
reinstall QGIS and then I found the same README.
I am excited to play with visvis.
David.
On Wed, Oct 17, 2012 at 10:12 AM, gene <martin.laloux at gmail.com> wrote:
> it is a problem of PATH
> *1) in the shell:*
> If you read the "Read Me.rtf" accompanying QGIS, the procedure is specified:
> "/The PyQt programs are included to compile UI and resource files for
> plugins. To use them, set these in your shell environment (you can add it
> to your ~/.bash_profile if you like):
> export PATH="/Applications/QGIS.app/Contents/MacOS/bin:$PATH"
> export PYTHONPATH="/Applications/QGIS.app/Contents/Resources/python"
> If you already have something in PYTHONPATH, add it instead with:
> export
> PYTHONPATH="/Applications/QGIS.app/Contents/Resources/python:$PYTHONPATH"
> Note that QGIS.app MUST be installed in /Applications and must not be
> renamed for pyuic4 to work (it has a hardcoded path in it)./"
> After that, you can use PyQt4 in the shell
>>>> import PyQt4
>>>> PyQt4.__file__
> '/Applications/QGIS.app/Contents/MacOS/../Resources/python/PyQt4/__init__.pyc'
> *2) In the console of QGIS*,
> This is not normal because the console itself is written in PyQt4
> 1) with QGIS 1.8
>>>> import PyQt4:
>>>> PyQt4.__file__
> '/Applications/*QGIS.app*/Contents/MacOS/../Resources/python/PyQt4/__init__.pyc'
> 2) with QGIS dev:
>>>> import PyQt4
>>>> PyQt4.__file__
> '/Applications/*QGIS_2.0-dev_SnoLeo.app*/Contents/MacOS/../Resources/python/PyQt4/__init__.pyc'
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Using-visualizing-3D-data-Z-values-tp4126375p5009339.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
