[Qgis-user] Building QGIS + GRASS 7
Etienne Tourigny
etourigny.dev at gmail.com
Thu Oct 18 08:13:50 PDT 2012
Unless I am mistaken, this was written before the release of grass 7.
SO >= 6.0.0 means that 5.x is not supported
BTW, if you go to the grass 7 page you can read
"This is the development version (SVN HEAD)
Not releases yet but the code is already usable"
So don't expect other products to support it before the first public release.
It might take more time after first release anyway...
cheers
Etienne
On Thu, Oct 18, 2012 at 11:04 AM, Vladimir Naumov <sendmeoffer at gmail.com> wrote:
> It's very strange since the official documentation of QGIS (INSTALL
> text file) states that it could be build with GRASS >= 6.0.0
> (libraries compiled with exceptions support on Linux 32bit).
> Regards,
> Vladimir.
> 2012/10/18 Ves Nikos <vesnikos at gmail.com>:
>> Hey Vladimir,
>> A year ago I tried to compile qgis with grass7. From what I could gather,
>> qgis can only be compiled with grass6.
>> I don't know if anything changed since then.
>> Regards,
>> Nick Ves
>> Στις 18/10/2012 4:27 μμ, ο/η Vladimir Naumov έγραψε:
>>> Hi list,
>>> I have similar problem as Paulo:
>>> http://lists.osgeo.org/pipermail/qgis-user/2012-April/016557.html
>>> I am trying to compile QGIS against the latest GRASS 7. But ccmake
>>> refuses to set variable LIB_PATH correctly, it uses its default one
>>> (/usr/lib/grass64/lib/libgrass_gproj.so).
>>> GDAL 1.9.2, released 2012/10/08
>>> GRASS version: 7.0.svn
>>> GRASS SVN Revision: 53433
>>> GIS Library Revision: 52468 (2012-07-28)
>>> GDAL/OGR: 1.9.2
>>> Python: 2.7.2+
>>> wxPython: 2.8.11.0
>>> Platform: Linux-3.0.0-26-generic-pae-i686-with-Ubuntu-11.10-oneiric
>>> Is it possible to build QGIS against GRASS 7? Why ccmake sets the
>>> variable to default?
>>> Best regards,
>>> Vladimir.
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
