[Qgis-user] QGIS Webclient negative bounds
Dieter Becker
webmapping.dieter at gmail.com
Thu Oct 18 23:55:36 PDT 2012
Hello to all,
I have got a questions concerning the QGIS-Webclient:
I tried to use negative values for the "startExtent=" and encountered a
problem that the qgis-webclient did not interpret this as correct values
and I got this error message:
start parameter "start-Extent" must be in OpenLayers.Bounds-Format
(left,bottom,right,top).
I used a Rest-Adress similar to this
http://webgis.uster.ch/maps/av/grundplan_av?format=image%2fpng%3b%20mode%3d8bit&visibleLayers=Abstandslinien,Nomenklatur,Fixpunkte,Geb%C3%A4ude,Grenzen,Einzelobjekte,Rohrleitungen,Bodenbedeckung,Liegenschaften%20Fl%C3%A4che,Einzelobjekte%20Unterst%C3%A4nde,Einzelobjekte%20Unterirdische%20Geb%C3%A4ude&fullColorLayers=Orthofoto%20aktuell%20(2010)&searchtables=&startExtent=692000,241500,700100,249000&maxExtent=692000,241500,700100,249000
but with negative values like startExtent=-180,-89,180,90
Did someone else also encounter this problem or has an idea how to solve it?
best wishes,
Dieter
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121019/191fbc9f/attachment.html>
