[Qgis-user] QGIS-Webclient Layer-visibility
Dieter Becker
webmapping.dieter at gmail.com
Fri Oct 19 00:13:51 PDT 2012
Dear QGIS-users,
I have got a questions concerning the layer-visibility of the
QGIS-Webclient:
In some older mails (11/2011) of this mailinglist I found following
information:
There is also a pending feature in QGIS server that should allow to
retrieve layer visibility from the GetCapabilities XML document, thus
eliminating the need to manually set layer visibility.
Andreas
Does someone of you know if there is found a convienient way in the
meantime to automatically determine the visible layers of a qgis-project so
that there is no need to write down everey layer for the rest-adress?
I know that for example the qgis-cloud-plugin for QGIS produces a js-config
file that has the information about visible layers and start-/maxExtent.
But is there also way to use something like this if I want to host my own
webclient?
best wishes,
Dieter
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121019/b63274a9/attachment.html>
