[Qgis-user] QGIS Webclient with two cgi-bin-directorys?
Andreas Neumann
a.neumann at carto.net
Fri Oct 19 00:24:17 PDT 2012
Hi Dieter,
This is possible, but you will have to separate the projects into
public and pw-protected projects and use some Apache rewriting rules.
Here is what I did:
cgi-bin/qgis_mapserv.fcgi is the publically available
cgi-bin/qgis_mapserv-eigentum.fcgi is a symbolic link to the main .fcgi
My projects reside in different directories:
projekte/av
projekte/orthofotos
are two publically available project folders
projekte_eigentum/av
is a pw-protected project folder (I mean pw-protected on the web).
Then in the apache-rewrite use the following:
RewriteEngine On
RewriteLog /var/log/apache2/webgis_rewrite.log
RewriteLogLevel 0
#Rewrite Rules for QGIS webclient
# Map /wms to qgis_mapserv.fcgi
RewriteRule ^/wms/(.+)$
/cgi/qgis_mapserv.fcgi?map=/home/www/projekte/$1.qgs [QSA,PT,L]
RewriteRule ^/wms-eigentum/(.+)$
/cgi/qgis_mapserv-eigentum.fcgi?map=/home/www/projekte_eigentum/$1.qgs
[QSA,PT,L]
# Map /maps to /qgis-web-client
# First handle the mapping of the starting html file
RewriteRule ^/maps/([^/.]+/{0,1}){1,7}$
/qgis-web-client/qgiswebclient.html [PT,L]
RewriteRule ^/maps-eigentum/([^/.]+/{0,1}){1,7}$
/qgis-web-client-eigentum/qgiswebclient.html [PT,L]
#handle all other files except start files (e.g. .css and .js files)
RewriteRule ^/maps/([^/.]+/){1,1}(.*)$ /qgis-web-client/$2 [PT,L]
RewriteRule ^/maps-eigentum/([^/.]+/){1,1}(.*)$
/qgis-web-client-eigentum/$2 [PT,L]
Then create a location with a pw-protection mechanism:
<LocationMatch
"/qgis-web-client-eigentum/*|/qgis_mapserv-eigentum.fcgi">
Order allow,deny
Allow from xxx.xxx.xxx.xxx #ip address or range that does not
require a pw
AuthUserFile /etc/apache2/passwords
AuthGroupFile /etc/apache2/groups
AuthName "GIS Uster: Eigentum von Liegenschaften"
AuthType Basic
Require group eigentumav
Satisfy any
</LocationMatch>
Then when using the pw-protected one, you should point to the other wms
location (fcgi file), which is just a symbolic link.
Maybe there is a better, more elegant way, but this is how it works for
me.
Please let me know if you have a better idea.
Andreas
On Fri, 19 Oct 2012 09:06:27 +0200, Dieter Becker wrote:
> Dear QGIS-users,
> I have got a questions concerning the QGIS-Webclient:
> I try to implement a webmapping-solution with qgis-server and qgis
> webclient.
> At the moment I have got this application running with
> login/password-restriction for the cgi-bin-folder as well as the
> webclient itself so that also the WMS-services are
> password-protected.
> Now I would also make it possible to produce some
> none-password-protected WMS-services at the same time?
> Is it possible just to use two cgi-bin folders and not to encrypt
> the second one?
> Did someone of you already has such a system up and running with a
> mixture of encrypted and non-encrypted services?
> best wishes,
> Dieter
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
