[Qgis-user] Third-party-baselayer / OpenLayers-Plugin
Andreas Neumann a.neumann at carto.net
Fri Oct 19 00:34:57 PDT 2012
 I don't know about this one. I think the QGIS cloud service is a
 modified version of the main trunk version. Similar to Lizmap.
 If you know some javascript, it is probably relatively easy to
 implement this on a OpenLayers level. OpenLayers already supports these
 base layers.
 Personally, I don't have this need, so I won't work on it. But if
 someone supplies a generally useful patch I wouldn't be against
 including it.
 You have to be aware though, that you restrict yourself to the
 projections offered by the base-layer tile services. No way to reproject
 that data currently.
 You may also want to contact Sourcepole and ask them if they would make
 this available in the trunk version of the web client.
 Andreas
 On Fri, 19 Oct 2012 09:27:02 +0200, Dieter Becker wrote:
> Dear QGIS-users,
> first of all sorry for posting a bunch of emails at the same
> day...but
> I wanted to split the topics into seperate emails so that is easier
> to
> answer to one of this questions.
> So here is my last question for today (hopefully):
> I read that in the QGIS-wish-list there is a pending question about
> the possibility of integrating third-party baselayers so that
> QGIS-Desktop users can use the OpenLayers-plugin and the webclient
> will also show the baselayers that are used in the QGIS-project.
> But isn't this function already written?
> The qgis-cloud-plugin for QGIS produces a mapconfig.js which has the
> information about which baselayer should be used for the webclient.
> and examples like http://qgiscloud.com/anitagraser/corine_austria
> [1] show the use of these background-layers.
> Wouldn't it be possible to use this technique just wo produce a
> simple
> js-config file for users who don't want to use the (very nice)
> hosting-service of giscloud? Or is this plugin not OpenSource?
> best wishes,
> Dieter
> Links:
> [1] http://qgiscloud.com/anitagraser/corine_austria
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
