[Qgis-user] missing folder path in SEXTANTE for Mac OS X
Irene Palumbo ire.palumbo at gmail.com
Fri Oct 19 02:38:53 PDT 2012
Hi to everyone!
Hoping this will help…
I'm working with platform OS X 10.8.2 (12C60) -Mountain Lion-
After installing the plugin SEXTANTE v. 1.0.7 ,while using the Sextante  Toolbox, I get an error message (see attached) for every command I choose in GRASS
Error text:
Could not load layer: /Users/Ire/sextante/tempdata/grassvbufferdistance7.shp
Check the SEXTANTE log to look for errors in algorithm execution
Algotithm History:
Sextante.runalg("grass:v.buffer.distance","/Users/Ire/Desktop/QGIS corso/Dati_corso_QGIS/punti.shp","100","0.01",False,False,None)
Sextante.runalg("grass:v.to.rast.value","/Users/Ire/Desktop/QGIS corso/Dati_corso_QGIS/fiumi.shp",0,1,None)
I noticed that in the options menu, in Grass configuration (and with SAGA is the same) is missing the line to enter the path for the GRASS folder, but I don't know if this is the real problem. (I've attached some images, because I'm not sure to have explained correctly what I meant….)
Thanks!
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121019/a2d173e3/attachment.html>
Name: Schermata 2012-10-19 alle 11.35.14.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121019/a2d173e3/attachment.png>
Name: Schermata 2012-10-19 alle 11.35.24.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121019/a2d173e3/attachment-0001.png>
