[Qgis-user] missing folder path in SEXTANTE for Mac OS X
Irene Palumbo ire.palumbo at gmail.com
Fri Oct 19 03:33:18 PDT 2012
Thank you Victor for answering.
I'll try doing the same things in Grass, hoping it will work!
I'll keep you updated, hoping for some other MAC users !
Regards,
Irene
Il giorno 19/ott/2012, alle ore 11:49, Victor Olaya <volayaf at gmail.com> ha scritto:
> No, that is not a problem
> If you are running Linux or Mac, GRASS and SAGA should be on your path, so there is no need to tell SEXTANTE where they are.
> I haven't done testing in Mac, so I cannot tell you much more about why it is not finding GRASS...sorry :-(  If you open a console and you can start grass, then you should not have problems. If not, make sure that GRASS is installed and in your path.
> Maybe someone with a Mac who has worked with SEXTANTE can help you more that I can...
> Regards
> VIctor
> 2012/10/19 Irene Palumbo <ire.palumbo at gmail.com>
> Hi to everyone!
> Hoping this will help…
> I'm working with platform OS X 10.8.2 (12C60) -Mountain Lion-
> After installing the plugin SEXTANTE v. 1.0.7 ,while using the Sextante  Toolbox, I get an error message (see attached) for every command I choose in GRASS
> Error text:
> Could not load layer: /Users/Ire/sextante/tempdata/grassvbufferdistance7.shp
> Check the SEXTANTE log to look for errors in algorithm execution
> Algotithm History:
> Sextante.runalg("grass:v.buffer.distance","/Users/Ire/Desktop/QGIS corso/Dati_corso_QGIS/punti.shp","100","0.01",False,False,None)
> Sextante.runalg("grass:v.to.rast.value","/Users/Ire/Desktop/QGIS corso/Dati_corso_QGIS/fiumi.shp",0,1,None)
> I noticed that in the options menu, in Grass configuration (and with SAGA is the same) is missing the line to enter the path for the GRASS folder, but I don't know if this is the real problem. (I've attached some images, because I'm not sure to have explained correctly what I meant….)
> Thanks!
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121019/f30bc49c/attachment.html>
