[Qgis-user] Editing Data in Attribute Table/How Do I Install
Nathan Woodrow madmanwoo at gmail.com
Sat Oct 20 20:02:24 PDT 2012
 MultiEdit
MIME-Version: 1.0
Content-Type: text/plain; charset="utf-8"
Content-Transfer-Encoding: 7bit
Leyan,
What kind of stuff were you after? QGIS does have a field calculator
which can do expressions for calculations.
Nathan
Sent: 21/10/2012 12:56 PM
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Editing Data in Attribute Table/How Do I
Install MultiEdit
Hi Ben,
If you work with shapefile, you can open the dbf file with LibreOffice
and do more advanced editing here. Be careful not to delete or reorder
lines. I agree it would be very nice to see these features included in
the attributes editing.
Leyan
On 10/20/2012 11:49 PM, Ben Jones wrote:
> Hi All,
> A couple of questions re editing data in the attribute table:
> 1) Is it possible to add/change attribute data to multiple selected items in one single operation (I'm presently selecting the items, opening the attribute table, ticking show selected only, and then manually pasting the relevant data into the row for each item)? Surely there is a more intelligent way to do this?
> 2) Is there a "find and replace" tool that can be used to change matching data to a new value when editing data in the attribute table?
> 3) The MultiEdit plugin (http://plugins.qgis.org/plugins/MultiEdit/) sounds like it may be helpful when editing data in the attribute table but I haven't been able to install it (it doesn't appear in the list of plugins in the plugin installer). How do I install this plugin?
> Thanks for your help,
> Ben
> Qgis-user mailing list
