[Qgis-user] How to find info about a feature in map?
Johan Nilsson
joni8135 at gmail.com
Sun Oct 21 02:56:56 PDT 2012
Thanks.
2012/10/21 S. Wagenaar <sw1234 at planet.nl>
> Use 'Identify features' from the View menu or the Attributes toolbar, or
> use Ctrl+Shift+I.
> Op 21-10-2012 9:57, Johan Nilsson schreef:
> Hi
> I can't find how I select the shape-file object (point, line or polygon)
> on the map and find it in the shape-file? For instance select a 'point' and
> find where it is in a layerfile and witch attribute it corensponding to.
> When I use 'select singel feauter' QGIS work, and a little symbol around
> the object appaers for a second, but dissappear again.
> /Cheers
> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121021/95ecb30a/attachment.html>
