[Qgis-user] Editing Data in Attribute Table/How Do I Install
Andreas Neumann a.neumann at carto.net
Mon Oct 22 00:42:44 PDT 2012
 Hi Leyan,
 Are you aware that there is a tool in the advanced editing toolbar
 called "Merge attributes of selected features". There are two identical
 icons next to each other. One also merges the geometries into one
 feature, the other one only sets all attributes of the selected features
 to the same attributes. It assigns the same attribute values to all
 features (except the primary key column). It allows you to set which of
 the selected features is used or you can calculcate mean/max/min or the
 most common attribute value.
 Hope this helps,
 Andreas
 On Sun, 21 Oct 2012 11:44:00 +0800, Leyan wrote:
> Hi Nathan,
> I know the field calculator and used it quite extensively. The
> functions are powerful but it can be quite cumbersome to use (I hope
> the future saved expressions can help for this, having to copy and
> paste from an external text editor is a pain). I would like to be
> able
> to:
> * sort according to several columns
> * auto-increment a field just by dragging the mouse like in a
> spreadsheet
> * for a numeric field, see quickly the basic statistics of the
> selected features (average, sum, maybe also min and max). Currently,
> I
> would have to go to Vector->Analysis->Basic statistics and select the
> field. I prefer to copy and paste the selected features to either
> LibreOffice or Excel and select the column I want to see the sum, but
> I don't know what to say each to people when I show them how to use
> QGIS (we work on networks so we are often interested in the length of
> lines in a selected area for example).
> * select several cells and copy/paste them
> * hide columns temporarily
> * having formulas that stay as formulas and are updated when the
> source data is updated, be it other fields, geometry, etc. ( I think
> I
> saw something about this but I do not know the current status)
> Anyway, just a few ideas I had in mind, probably more would come
> later. I wanted to implement the basic statistics of selection
> myself,
> but am I not sure of where to put this, there is no status bar.
> Leyan
> On 10/21/2012 11:02 AM, Nathan Woodrow wrote:
>>   MultiEdit
>> MIME-Version: 1.0
>> Content-Type: text/plain; charset="utf-8"
>> Content-Transfer-Encoding: 7bit
>> Leyan,
>> What kind of stuff were you after? QGIS does have a field calculator
>> which can do expressions for calculations.
>> Nathan
>> From: Leyan
>> Sent: 21/10/2012 12:56 PM
>> To: qgis-user at lists.osgeo.org
>> Subject: Re: [Qgis-user] Editing Data in Attribute Table/How Do I
>> Install MultiEdit
>> Hi Ben,
>> If you work with shapefile, you can open the dbf file with
>> LibreOffice
>> and do more advanced editing here. Be careful not to delete or
>> reorder
>> lines. I agree it would be very nice to see these features included
>> in
>> the attributes editing.
>> Leyan
>> On 10/20/2012 11:49 PM, Ben Jones wrote:
>>> Hi All,
>>> A couple of questions re editing data in the attribute table:
>>> 1) Is it possible to add/change attribute data to multiple selected
>>> items in one single operation (I'm presently selecting the items,
>>> opening the attribute table, ticking show selected only, and then
>>> manually pasting the relevant data into the row for each item)?
>>> Surely there is a more intelligent way to do this?
>>> 2) Is there a "find and replace" tool that can be used to change
>>> matching data to a new value when editing data in the attribute
>>> table?
>>> 3) The MultiEdit plugin
>>> (http://plugins.qgis.org/plugins/MultiEdit/) sounds like it may be
>>> helpful when editing data in the attribute table but I haven't been
>>> able to install it (it doesn't appear in the list of plugins in the
>>> plugin installer). How do I install this plugin?
>>> Thanks for your help,
>>> Ben
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
