[Qgis-user] ubuntu 12.10 issues
Nicholas Efremov-Kendall n.e.kendall at gmail.com
Sat Oct 27 01:50:07 PDT 2012
In response to your email
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package 'qgis' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
nizzok at eratosthenes:~$ sudo apt-get install qgis
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help resolve the situation:
The following packages have unmet dependencies:
 qgis : Depends: qgis-providers (= 1.8.0-1~quantal1) but it is not going to
be installed
        Depends: qgis-common (= 1.8.0-1~quantal1) but
1.9.0+git20121015+5afd739~precise-ubuntugis1 is to be installed
        Recommends: qgis-plugin-globe but it is not going to be installed
        Recommends: qgis-plugin-grass but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
and the same if qgis was purged
On Fri, Oct 26, 2012 at 10:22 PM, Rudi von Staden <rudivs at gmail.com> wrote:
> Okay, that doesn't look too bad, Nicholas. Definitely change the "precise"
> to "quantal" in your http://extras.ubuntu.com/ubuntu repo (or disable it
> entirely by putting a # in front of the deb and deb-src entries - you
> shouldn't need anything there to get qgis working). You only have the one
> ppa enabled, which is the right one if you want to install qgis 1.8.0.
> What happens if you run the following commands?
> sudo apt-get update
> sudo apt-get remove qgis
> On Sat, Oct 27, 2012 at 9:19 AM, Nicholas Efremov-Kendall <
> n.e.kendall at gmail.com> wrote:
>> Hi Rudi,
>> Thanks in advance and here you go:
>> $ cat /etc/apt/sources.list /etc/apt/sources.list.d/*.list | grep ppa
>> # deb http://ppa.launchpad.net/olivier-berten/geo/ubuntu quantal main #
>> disabled on upgrade to quantal
>> # deb-src http://ppa.launchpad.net/olivier-berten/geo/ubuntu quantal
>> main # disabled on upgrade to quantal
>> # deb http://ppa.launchpad.net/sharpie/for-science/ubuntu quantal main #
>> # deb-src http://ppa.launchpad.net/sharpie/for-science/ubuntu quantal
>> # deb http://ppa.launchpad.net/sharpie/postgis-stable/ubuntu quantal
>> # deb-src http://ppa.launchpad.net/sharpie/postgis-stable/ubuntu quantal
>> deb http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu quantal
>> deb-src http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntuquantal main # disabled on upgrade to quantal
>> and
>> # deb cdrom:[Ubuntu 11.04 _Natty Narwhal_ - Release i386 (20110427.1)]/
>> natty main restricted
>> # See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
>> # newer versions of the distribution.
>> deb http://ca.archive.ubuntu.com/ubuntu/ quantal main restricted
>> deb-src http://ca.archive.ubuntu.com/ubuntu/ quantal main restricted
>> ## Major bug fix updates produced after the final release of the
>> ## distribution.
>> deb http://ca.archive.ubuntu.com/ubuntu/ quantal-updates main restricted
>> deb-src http://ca.archive.ubuntu.com/ubuntu/ quantal-updates main
>> restricted
>> ## N.B. software from this repository is ENTIRELY UNSUPPORTED by the
>> Ubuntu
>> ## team. Also, please note that software in universe WILL NOT receive any
>> ## review or updates from the Ubuntu security team.
>> deb http://ca.archive.ubuntu.com/ubuntu/ quantal universe
>> deb-src http://ca.archive.ubuntu.com/ubuntu/ quantal universe
>> deb http://ca.archive.ubuntu.com/ubuntu/ quantal-updates universe
>> deb-src http://ca.archive.ubuntu.com/ubuntu/ quantal-updates universe
>> Ubuntu
>> ## team, and may not be under a free licence. Please satisfy yourself as
>> to
>> ## your rights to use the software. Also, please note that software in
>> ## multiverse WILL NOT receive any review or updates from the Ubuntu
>> ## security team.
>> deb http://ca.archive.ubuntu.com/ubuntu/ quantal multiverse
>> deb-src http://ca.archive.ubuntu.com/ubuntu/ quantal multiverse
>> deb http://ca.archive.ubuntu.com/ubuntu/ quantal-updates multiverse
>> deb-src http://ca.archive.ubuntu.com/ubuntu/ quantal-updates multiverse
>> ## Uncomment the following two lines to add software from the 'backports'
>> ## repository.
>> ## N.B. software from this repository may not have been tested as
>> ## extensively as that contained in the main release, although it includes
>> ## newer versions of some applications which may provide useful features.
>> ## Also, please note that software in backports WILL NOT receive any
>> review
>> ## or updates from the Ubuntu security team.
>> # deb http://ca.archive.ubuntu.com/ubuntu/ natty-backports main
>> restricted universe multiverse
>> # deb-src http://ca.archive.ubuntu.com/ubuntu/ natty-backports main
>> deb http://security.ubuntu.com/ubuntu quantal-security main restricted
>> deb-src http://security.ubuntu.com/ubuntu quantal-security main
>> restricted
>> deb http://security.ubuntu.com/ubuntu quantal-security universe
>> deb-src http://security.ubuntu.com/ubuntu quantal-security universe
>> deb http://security.ubuntu.com/ubuntu quantal-security multiverse
>> deb-src http://security.ubuntu.com/ubuntu quantal-security multiverse
>> ## Uncomment the following two lines to add software from Canonical's
>> ## 'partner' repository.
>> ## This software is not part of Ubuntu, but is offered by Canonical and
>> the
>> ## respective vendors as a service to Ubuntu users.
>> deb http://archive.canonical.com/ubuntu quantal partner
>> # deb-src http://archive.canonical.com/ubuntu natty partner
>> ## This software is not part of Ubuntu, but is offered by third-party
>> ## developers who want to ship their latest software.
>>  deb http://extras.ubuntu.com/ubuntu precise main
>>  deb-src http://extras.ubuntu.com/ubuntu precise main
>> On Fri, Oct 26, 2012 at 9:14 PM, Rudi von Staden <rudivs at gmail.com>wrote:
>>> Hi Nicholas,
>>> It sounds like your repositories are in a bit of a mixed-up state if you
>>> upgraded to 12.10 (quantal) and your sources.list has repos from 12.04
>>> (precise). Also if your sources gui is broken, you might need to get ubuntu
>>> to a stable state before looking at qgis. The first step is to check what
>>> repositories and ppa's you have enabled.  Could you attach or paste your
>>> full /etc/apt/sources.list file? Also the output of this command run from
>>> the terminal:
>>> Kind regards,
>>> Rudi
>>> On Sat, Oct 27, 2012 at 5:36 AM, Nicholas Efremov-Kendall <
>>>> Hi Rudi,
>>>> Yes, at this point I just want to go back to a stable version. i've
>>>> changed my repos in etc/apt/sources.list to
>>>> and I still get this as an error in terminal.
>>>> 1.9.0+git20121014+2754df0~precise1 is to be installed
>>>> So, how do I roll back to 1.8? Also, my software sources gui is broken.
>>>> On Wed, Oct 24, 2012 at 12:20 AM, Rudi von Staden <rudivs at gmail.com>wrote:
>>>>> Hi Nicholas,
>>>>> My guess would be that during the upgrade, some of your repositories
>>>>> were turned off. qgis (1.74+1.75~20120320-1.1) is the version in the 12.10
>>>>> ubuntu repository, but it looks like you previously installed qgis from the
>>>>> master repository (1.9.0+git20121015+5afd739~precise-ubuntugis1).
>>>>> If you still want to use the cutting-edge qgis version, check in your
>>>>> software sources (Ubuntu Software Center > Edit > Software Sources; then
>>>>> Other Software tab) for something with "http://qgis.org/debian-nightly"
>>>>> in it. Check that it now reads "http://qgis.org/debian-nightlyquantal", and enable it. Then from the command line, run "sudo apt-get
>>>>> update && sudo apt-get install qgis". If that still doesn't work, I'd
>>>>> remove qgis (sudo apt-get remove qgis), and then try to reinstall it (sudo
>>>>> apt-get install qgis).
>>>>> If you'd rather revert to a more stable and tested version of qgis,
>>>>> the instructions may be different...
>>>>> Kind regards,
>>>>> Rudi
>>>>> On Wed, Oct 24, 2012 at 11:38 AM, Nicholas Efremov-Kendall <
>>>>>> Hi All,
>>>>>> Still having issues with my ubuntu install. I just upgraded to 12.10,
>>>>>> but I was having problems before. It looks like the system is expecting 1.7
>>>>>> dependencies, but tries to install 1.9 and fails.
>>>>>>  qgis : Depends: qgis-providers (= 1.7.4+1.7.5~20120320-1.1) but
>>>>>>         Depends: qgis-common (= 1.7.4+1.7.5~20120320-1.1) but
>>>>>> installed
>>>>>> Any ideas?
>>>>>> _______________________________________________
>>>>>> Qgis-user mailing list
>>>>>> Qgis-user at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121026/ab78ce48/attachment.html>
