[Qgis-user] Loosing connection to SVG Markers
Andreas Neumann a.neumann at carto.net
Mon Oct 29 08:45:36 PDT 2012
I am not aware about such path length restrictions.
For the symbol that does not work - did you open the .qgs project file
in a text editor and search for the SVG file? Did you check what path is
stored in the project file?
For production work I recommend to have a central repository of SVG
symbols and use relative paths instead of absolute paths. Relative paths
for SVG symbols are defined as relative to the SVG symbol repository.
If your central repository is at
\\yourserver\qgis\svgsymbols
and you use the path /water/valve_symbol.svg
It will look in your central repository and concatenate the path to
\\yourserver\qgis\svgsymbols\water\valve_symbol.svg
You can define the paths for the central repositories in the global
options (Settings --> Options --> Rendering tab --> bottom of the tab).
Hope this helps,
Andreas
Am 29.10.2012 16:08, schrieb magerlin:
> Are there any restriction on (length/levels of) paths to svg markers in new
> symbology?
> I am using this SVG marker in a Qgis project:
> C:\Program Files (x86)\Quantum GIS
> Lisboa\apps\qgis\svg\osm_icon\gpsicons\cam_ang_bl.svg
> It starts to work with no problem but it is not saved in the project or in
> qml files.
> When I reopen the project I have no icon on this layer.
> The qml file hold this path: /osm_icon/gpsicons/cam_ang_bl.svg. I assume
> that the first part  (C:\Program Files (x86)\Quantum GIS
> Lisboa\apps\qgis\svg\) should be delivered by Qgis?
> But even if I manually ask to load the qml-file nothing happens...
> Chosing another svg marker like:
> Lisboa\apps\qgis\svg\transport\transport_aerodrome.svg
> works without problems?
> Moving cam_ang_bl.svg to the above folder makes this svg work too...
> Does the path "C:\Program Files (x86)\Quantum GIS
> Lisboa\apps\qgis\svg\osm_icon\gpsicons\" perhaps contain to many subfolders?
> Regards Morten
> Qgis 1.8.0 Stand alone installer in Win7 64 bit
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Loosing-connection-to-SVG-Markers-tp5012025.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
