[Qgis-user] QGIS Server and CSV-files
Marco Lechner marco.lechner at fossgis.de
Mon Oct 29 11:57:46 PDT 2012
I think I remember CSV is also supported by OGR this might work. An body may correct if this is wrong.
Andreas Neumann <a.neumann at carto.net> schrieb:
>I don't know.
>CSV files are loaded with a plugin - they are not part of the core data
>providers.
>Marco Hugentobler would have to answer this question. I can't answer it,
>sorry.
>If you have the chance to use a database (SpatiaLite or Postgis) those
>are much preferred over csv files. Performance would be better and
>handling would be easier.
>Andreas
>Am 29.10.2012 15:42, schrieb Thomas Baumann:
>> Hello,
>> just a quick question concerning the qgis-server:
>> Is it possible to use QGIS-project-files that contain csv-layers?
>> I just tried to load a wms-service from such a project-file and get an "500
>> Internal Server Error".
>> If I use qgs-files in combination with shapefiles this error does not occur.
>> In the apache-log I found:
>> mod_fcgid: *error reading data*, FastCGI server closed connection,
>> Premature end of script headers: qgis_mapserv.fcgi,
>> [error] mod_fcgid: process /usr/lib/cgi-bin/qgis_mapserv.fcgi(9137)
>> exit(communication error), get unexpected signal 11
>> best wishes,
>> Thomas
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
