[Qgis-user] Georeferencing Crash
Steve Katzberg stevekatzberg at bellsouth.net
Wed Oct 31 06:12:18 PDT 2012
All,
Thank you for replying.  The problem appears related to the starting of an
X-window or whatever is the equivalent in Ubuntu with Qgis.  Once Qgis went
unstable the first time, I could "kill 'pid' " to stop it but upon restart
of Qgis, all that appears is a highly unstable bit of graphics rapidly
jumping around and not accessible in any way via mouse-click.  I have purged
Qgis, reinstalled Qgis, started it from the luncher and from the command
line, with and without plug-ins.  Always the same problem.  On reinstall,
the Qgis graphic comes up fine, says it is starting and then the Hints
graphic comes up and immediately behind the correct grapics, the rapid lines
with no correct rendering of anything.  I think the original instability has
somehow damaged the Ubuntu and I don't know how to fix it.
By the way, the Qgis icon on the start menu rapidly pulsates.
Steve Katzberg
----- Original Message -----
From: "Alex Mandel" <tech_dev at wildintellect.com>
To: <qgis-user at lists.osgeo.org>
Sent: Wednesday, October 31, 2012 2:51 AM
Subject: Re: [Qgis-user] Georeferencing Crash
That might be it, but there good be other possibilities.
Which version did you install and from which repository?
Which transformation did you pick?
Have you run qgis from command line to see if it dumps and error message
when the crash happens.
Thanks,
Alex
On 10/30/2012 11:33 PM, Lene Fischer wrote:
> Hi  Steve
> Yhere are a reported bug on georeferencing.
> The first try will be OK. The next goes wrong because the program remember
> the previous coordinates. The workaround - until we see a bugfix - is to
> close down QGIS and restart the program.
> Regards
> Lene Fischer
> ________________________________
> Fra: qgis-user-bounces at lists.osgeo.org [qgis-user-bounces at lists.osgeo.org]
> på vegne af Steve Katzberg [stevekatzberg at bellsouth.net]
> Sendt: 31. oktober 2012 03:06
> Til: qgis-user at lists.osgeo.org
> Emne: [Qgis-user] Georeferencing Crash
> I am an ArcView/Windows user and also have Linux/Ubuntu Precise on another
> computer.  I needed some enhancements to the ArcView I have and decided to
> install Qgis on the Linux computer.  All went well and I built a couple
> projects that look very good.  I then tried the main target for the
> installation, georeferencing.  After some attemps I got to the point of
> generating contol points which did not go well.  The gui dissolved into a
> set of pulsating lines across the work area.  I used both "kill" and the
> gui "quit" which ultimately both methods succeeded in stopping the Qgis,
> or what was left of it.  Subsequently I used apt-get to remove and
> reinstall Qgis to no avail, making sure to restart the computer each time.
> Reinstallation did not fix the pulsating lines on the monitor.  Obviously
> Qgis has hosed some other software that it needs and it will not work.
> I'd like a little help on how to get Qgis back working.
> Steve Katzberg
> Qgis-user mailing list
