[Qgis-user] Many greyed tools in qgis 1.8.01 menu
Agustin Lobo alobolistas at gmail.com
Fri Sep 14 07:18:27 PDT 2012
Problem solved by closing the Layers panel and opening it again
with View/Panels/Layers
kind of weird.
Agus
On Fri, Sep 14, 2012 at 10:03 AM, Agustin Lobo <alobolistas at gmail.com> wrote:
> I'm having an unexpected behaviour of qgis 1.8.01 on ubuntu 10.04:
> when I open a project (no matter recent or old) many tools
> are disabled, including layer/properties. Also, the right button of
> the mouse does not work.
> See picture here:
> http://dl.dropbox.com/u/3180464/greyed.jpg
> If I load any layer, then the right button keeps on failing but the
> tools are no longer
> greyed. I can remove the layer, the buttons keep working. But even if
> I save the project
> (no matter with or without the new layer), the next time I start qgis
> (or just open the project) the tools are greyed again until I load
> another layer.
> I have tried with qgis --noplugins : same problem
> I observe that Control rendering order is off by default (not sure how
> it was before).
> May be there is some option that I'm not aware of?
> The same projects work fine on a Mac.
> Thanks for any help.
> Agus
