[Qgis-user] Copy / paste features to spatialite generates
Julian Bogdani
jbogdani at gmail.com
Mon Sep 17 01:07:34 PDT 2012
Hi Josef
and thank you for your reply. I am actually using Qspatialite plugin to manage my spatialite layers. I checked the metadata of my database and my geometry column is of type MULTISTRING.
I use Qspatialite to transform shapefiles in spatialite and the other way, but I'm not sure how to use it to copy only some feature from a shapefile to a spatialite table. I think I have to upload it to the spatialite archive and then use sql to copy data from one table to another.
I'm afraid this is not so user-friendly, and my colleagues can hardly handle data in this way. Maybe actually it's better to continue using shapefiles as feature containers and wait until spatialite becomes a little bit more handily.
Julian Bogdani
http://bradypus.net
On 17 Sep 2012, at 2:01 , Josef K wrote:
> Hi Julian
> I guess your problem is related to geometry types (http://www.gaia-gis.it/spatialite-2.4.0-4/spatialite-cookbook/html/new-geom.html). Try to define your spatialite geometries as multipoint, multilinestring and multipolygons. Then they will be more compatible with shapefiles and you may copy/paste in qgis.
> Although I would recommend that you tried using spatialite-gui (or perahaps qspatialite) instead. By those tools you can temporarily upload the shapefile to your database file and then use sql syntax 'insert into ... select ... ' the features you want into your db tables. Using sql syntax will give you more control of fields, data types etc.
> regards
> Josef
> Date: Sun, 16 Sep 2012 11:53:30 +0200
> From: Julian Bogdani <jbogdani at gmail.com>
> To: qgis-user <qgis-user at lists.osgeo.org>
> Subject: [Qgis-user] Copy / paste features to spatialite generates
> error
> Message-ID: <A7512D49-0F85-4CB5-A3D2-85DA4919E24C at gmail.com>
> Content-Type: text/plain; charset=us-ascii
> Hello all,
> I've tried to add to an existing spatialite layer some features from another layer.
> The existing layer is a simple shapefile: I selected the features I wanted to copy and pasted to the spatialite layer. Everything was working file until I tried to save the changes. The following error appears:
> Could not commit changes to layer Plan_gen
> Errors: ERROR: 903 feature(s) not added.
> Provider errors:
> SQLite error: Plan_gen.Geometry violates Geometry constraint [geom-type or SRID not allowed]
> SQL: INSERT INTO "Plan_gen"("PKUID","Geometry","Layer","area") VALUES (NULL,GeomFromWKB(?, 32634),?,?)
> it states it might be a problem of geometry type or a SRID problem. All layers are in the same CRS (EPSG:32634), and all features, in both layers, are of type polyline.
> Is it a spatialite bug? a qgis bug? or Am I missing anything?
> I've had this issue with other data before. The solution I adopted to work around this was:
> 1) save the spatialite layer as shapefile
> 2) paste data into the newly created shapefile
> 3) delete the spatialite table
> 4) load in the spatialite DB the shapefile
> This works, but it is too tricky for everyday use. I tried to convert all my shapefiles to spatialite, but the limitation spatilite still have in data structure manipulation (adding/removing/renaming fields, etc, a sqlite limit in fact) and now in content editing make me think that that was not a good idea. I can not switch this archives to postGIS yet, because of the actual work-flow organization of the project.
> Any help or advice will be appreciated!
> Julian Bogdani
> http://bradypus.net
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120917/cee6f22f/attachment.html>
