[Qgis-user] Layers in qgs file not present in the Layers pane
Ramon AndiƱach custard at westnet.com.au
Mon Sep 17 15:38:03 PDT 2012
On 18/09/2012, at 4:08, Julian Bogdani <jbogdani at gmail.com> wrote:
> Hello
> I've posted a question on gis.stackexchange.com (http://gis.stackexchange.com/questions/33608/layers-in-qgs-file-not-present-in-the-layers-pane), and as promised there I'm sending here a qgis project file with a phantom layer to use for test.
[snip]
> As you can see in the same file other traces of older files are still present in the xml, for instance near lines126 and following: a list of vector layer with snapping turned on. This does not produce any error, but getting them removed when layer is removed is probably cleaner.
As a you're not hallucinating comment (rather than a solution) I also have seen such things, although I'm not sure I have an example to hand.
Is it just in projects saved by QGIS 1.8?
I think from memory mine are with relative paths, and are projects originally started under an earlier QGIS version.
Save As did not work for me either.
-ramon.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120918/e15cc977/attachment.html>
