[Qgis-user] downsample dem in qgis?
Chris Henrick chrishenrick at gmail.com
Thu Sep 20 10:28:15 PDT 2012
thanks Micha. I'll give it a shot.
Have you worked with downsampling dems to create hillshades? I'm wondering
if there is a general resolution to scale ratio one could abide by to
create appropriately detailed hillshades...
-Chris
On Wed, Sep 19, 2012 at 11:15 PM, Micha Silver <micha at arava.co.il> wrote:
>  I think the way to do this is with gdalwarp. Use the -tr (target
> resolution) parameter and -r (resampling method) to get the resolution you
> want.
> On 19/09/2012 23:04, Chris Henrick wrote:
> Hello, I've read in the gdal wiki that there is the potential to
> downsample a dem when using gdal_translate. However I cannot figure out
> what parameters to set in order to do so if running the command from either
> QGIS or shell.
>  My goal is to downsample dems to make more generalized shaded reliefs.
>  Any advice would be appreciated, I'm on mac os 10.6 with qgis 1.8.
>  regards,
> -Chris
> This mail was received via Mail-SeCure System.
> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
> Micha Silver
> 052-3665918
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120920/668fb84a/attachment.html>
