[Qgis-user] gfx in WSG 84 added to another CRS (EPSG:3021)
leyan ouyang
ouyang.leyan at hotmail.com
Fri Sep 21 00:10:37 PDT 2012
Yes it is possible, the option "on-the-fly reprojection" does just that. Choose the main CRS as the project CRS (it will be used for distance calculations, etc.). Then when you add a layer you can choose its CRS individually, QGIS will do the transformation.
Regards,
Leyan
Date: Fri, 21 Sep 2012 09:08:05 +0200
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] gfx in WSG 84 added to another CRS (EPSG:3021)
Hi.
I can transform gpx file from a GPS (WSG84) to an old swedisch CSR EPSG:3021 (RT90 2,5 gon V metric coordinate system)) shape file, but I whant to let the program transform on the fly.
I know that year 1999 Silicon graphic had it on there 'super coomputers' and GIS-softwate, and I also see that QGIS have under menue:
Settings-->Options-->CRS-tab have an option to check 'on the fly reprojection' in option.
Under options-->CRS can you define default project CRS and defaut CRS to what your add in layers, but If you have a lot of old files with diffenent CRS it could be errors. Now Sweden is in transition from RT90 to SweRef99 (very near WSG84)
Is it possible to add vector files with other CRS, or even rasters to a project without transform it?
/Cheers
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120921/7935163a/attachment.html>
