[Qgis-user] it's posible to select units for scale bar?
Frank Sokolic sokolic at worldonline.co.za
Fri Sep 21 02:51:43 PDT 2012
Hi Aitor,
You'll have to enable 'on the fly' transformation in the Project Properties and then choose a CRS that projects everything to a metres-based CRS, e.g. UTM. Once you've done this the scale bar in your composer will be in metres.
By the way, the ArcGIS scale bar you mention isn't accurate. ArcGIS will happily allow you to choose km or metres for your scale bar units even when you are using geographic coordinates for your data frame but the length of the scale bar will be WRONG. You can test this by using the measuring tool to measure the length as indicated by the scale bar - you'll get a different length.
Frank.
Sent:2012-09-21 11:15:34
To: qgis-user at lists.osgeo.org
Cc:
Subject: [Qgis-user] it's posible to select units for scale bar?
My issue is simple, when I make a map with composer, if I use a
geographic coordinate reference system, I can't select meters like
units for scale bar.
For me it's fine, but my boss don't understand degrees like measuring
unit in the maps, and then it's a problem for me. I know that with
arcgis software you can choose the units so it´s possible to do that.
Would be difficult to incorporate it into future versions or something
like a pluging?
Congratulations for the program, it's great!!
Hugs.
[Off-topic] +1 for the spanish list!!
Aitor Freire Astray
User of QGIS version 1.9.0-Master (code revision 5e5370)
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120921/6bd930c4/attachment.html>
