[Qgis-user] Fwd: "Normal" mdb support possible for "normal" people?
Andre Joost andre+joost at nurfuerspam.de
Sat Sep 22 05:17:28 PDT 2012
Am 22.09.2012 13:47, schrieb Micha Silver:
> On 09/22/2012 10:27 AM, Andre Joost wrote:
>>  Am 22.09.2012 09:17, schrieb Johan Nilsson:
>>>  There is another thing with 'Personal geodatabase' and that is that ESRI
>>>  don't recommend to use it in their documentation because it slow and get
>>>  really slow if they are bigger and the absolute size are limited.
>>  Yes, that's true. Spatial index will not be possible on MDBs (as well as on
>>  spataialite). But MS Access is widely spread, so a connection would be highly
>>  appreciated. And MDBs are easily portable (again, as well as spatialite).
>>  Thats a great advantage to Postgis.
> I'm not sure I understood your comment, but spatial indexing is definitely
> supported in Spatialite using the R*Tree structure.
I referred to the spatialite 2.1 manual still first in Google search.
I guess its not fully supported by the stable Qgis 1.8.0.
In DB Manager, I have an entry Spatial Index, but get an error
"no such module: VirtualSpatialIndex". Qspatialite throws an error for
the same reason, and a message "No spatial index defined".
I read that spatialitegui might solve the problem, but I want to work
inside Qgis. So still nothing for "normal" people ;-)
Using Master I get other errors about missing pyspatialite.
Gruß,
André Joost
