[Qgis-user] color ramp plugin broken ?
Etienne Tourigny etourigny.dev at gmail.com
Mon Sep 24 04:55:14 PDT 2012
On Mon, Sep 24, 2012 at 3:39 AM, Andre Joost <andre+joost at nurfuerspam.de> wrote:
> Am 23.09.2012 21:53, schrieb Etienne Tourigny:
>> I haven't made any docs yet, I though it was straight-forward to use,
>> but I guess not.
> As a software user, I can tell you that this almost never works ;-)
>> First you select the package you want
>> -  Use gradients that ship with qgis ->  uses the minimal selection
>> laready present
>> -  QGis selection ->  free to distribute selection, about 800 gradients
>> - Full cpt-city selection ->  all gradients,(about 6000)
>> Next you select the installation folder - if you are the only user,
>> you can select your profile folder $HOME/.qgis
>> Then you click Update, package is downloaded and installed.
>> Go to the style manager->Color ramps and add a new ramp "cpt-city",
>> you can browse by selection of by author.
>> Every 7 days the plugin looks for updates, and you can manually check
>> by clicking update. But this shouldn't happen too often.
> You should add that it looks for updates of the color ramps, not updates of
> the plugin itself ;-)
the plugin manager does that, but I see what you mean!
>> There ya go!
> What about a little help button at the bottom with this information?
Will do.  cheers
> Greetings,
> André Joost
> Qgis-user mailing list
