[Qgis-user] Colour field in the style box
欧阳乐岩
ouyang.leyan at hotmail.com
Mon Sep 24 06:10:33 PDT 2012
It can be done for the ellipse symbol, even though it is quite hidden.
You should create a string field with your color defined as #RRGGBB
using the hexadecimal values for red, green and blue. You can also use
the named colors from this list :
http://www.w3.org/TR/SVG/types.html#ColorKeywords or the keyword
"transparent"
Regards,
Pierre
On 09/24/2012 05:09 AM, Rhys A.D. Stewart wrote:
> Greetings all!,
> Hope all is well. I think it would be great if their was a colour
> field in the same vein as the rotation and scale fields in the Layer
> Properties/Style dialog box. That way one could just pull the colour
> for the feature straight from the provider. Would also reduce compute
> time if one needs to categorize stuff.
> Regards,
> Rhys
