[Qgis-user] QT-Designer
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Mon Sep 24 07:05:47 PDT 2012
I don't think that the path you found is an installation of QTDesigner
but rather the "connection" between qgis and the forms you create and load.
I installed the QT4 Designer as part of a huge programm from Nokia,
cause googling for that stuff didn't yield any other source.
http://qt-project.org/downloads
Its the QT Creator SDK which has 1.7 GB to download and with which you
could program design all kinds of user interfaces. Somewhere hidden in
the many things you can do there and which i do not understand at all,
you find an option to create QT Designer User Form.
Be sure to check QT Designer while installing, cause i missed that part
and searched for ages for the QT Designer stuff, and only found out by
installing again and then finding the checkbox and everything was there
then.
 From that point on everything is quite easy, as you only have to drag
new fields in your form and rename them according to your field names of
your tabel.
If anyone knows an easier way to get hands on the QT-Designer than
installing this huge creator thing, it would be nice to be told about it.
Greetz
Bernd
Am 24.09.2012 14:36, schrieb Sylvia Preuß:
> Dear list,
> how can I create a *.ui file with qt-designer? I want to create a new
> object with attributes and would like to use my own form to insert the
> attributes.
> C:\Programme\Quantum GIS Wroclaw\apps\Python27\sip\PyQt4\QtDesigner is
> installed. But I don't know how to get it started.
> Postgis-Layer, Wroclaw
> Best regards
> Sylvia
> Der E-Mail-Dienst des Oberbergischen Kreises dient ausschließlich der
> dienstlichen Kommunikation.
> Senden Sie deshalb keine E-Mails privaten Inhalts an E-Mail-Adressen
> des Oberbergischen Kreises.*
> Es wird darauf hingewiesen, dass neben der Person, an die Ihre E-Mail
> gerichtet ist, auch deren Vertretung im Amt einen unmittelbaren
> Zugriff auf Ihre Nachricht hat. Für Berufsgeheimnisträger und
> besondere Funktionsträger gelten abweichende Regelungen.
> Es wird außerdem darauf hingewiesen, dass die Kommunikation per E-Mail
> o hne Authentifizierung und Verschlüsselung unsicher ist, da für
> unberechtigte Dritte grundsätzlich die Möglichkeit der Kenntnisnahme
> und Manipulation besteht.
> Es wird deshalb keine Verantwortung für den Inhalt dieser Nachricht
> übernommen, da eine Manipulation nicht ausgeschlossen werden kann.
> Obwohl alle angemessenen Vorkehrungen getroffen wurden, um
> sicherzustellen, dass Anlagen dieser E-Mail virusgeprüft sind, wird
> empfohlen, anhängende Dateien vor dem Öffnen durch Ihr eigenes
> Virus-Programm zu prüfen, da keinerlei Haftung für Schäden übernommen
> wird, die infolge etwaiger Software-Viren entstehen könnten.
> Der Inhalt dieser E-Mail ist ausschließlich für die bezeichnete Person
> bestimmt. Wenn Sie nicht der vorgesehene Adressat dieser E-Mail oder
> dessen Vertretung sein sollten, beachten Sie bitte, dass jede Form der
> Kenntnisnahme, Veröffentlichung, Vervielfältigung oder Weitergabe des
> Inhalts dieser E-Mail unzulässig ist. In diesem Fall wird darum
> gebeten, sich mit der absendenden Person der E-Mail in Verbindung zu
> setzen.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120924/b1425c93/attachment.html>
