[Qgis-user] "Normal" mdb support possible for "normal" people?
Alister Hood Alister.Hood at synergine.com
Mon Sep 24 16:49:06 PDT 2012
> Date: Mon, 24 Sep 2012 09:14:29 +0200
> From: Even Rouault <even.rouault at mines-paris.org>
> To: Etienne Tourigny <etourigny.dev at gmail.com>
> Cc: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] "Normal" mdb support possible for "normal"
> 	people?
> Message-ID: <1348470869.5060085548069 at imp.free.fr>
> Content-Type: text/plain; charset=ISO-8859-1
> Selon Etienne Tourigny <etourigny.dev at gmail.com>:
> > On Sun, Sep 23, 2012 at 5:15 PM, Even Rouault
> > <even.rouault at mines-paris.org> wrote:
> > > Le dimanche 23 septembre 2012 21:58:30, Etienne Tourigny a ?crit :
> > >> Hi Even,
> > >> can you comment on using the java jackcess library? It's probably the
> > >> only cross-platform solution. Does it support normal mdb files, and
> if
> > >> not, can it benefit from your recent additions?
> > >> http://www.gdal.org/ogr/drv_mdb.html
> > >> http://jackcess.sourceforge.net/
> > > The MDB driver (with Jackcess library) indeed already supports normal
> MDB
> > > files. But it is a bit of a pain to use (needs linking GDAL with a JVM
> and
> > the
> > > Jackess .jar), so the latest improvement to the ODBC driver should
> make it
> > > easier.
> > But your improvements are only supported in windows, right?
> Yes. But there would be no problems to make it work on Linux too, like it
> is
> done in the PGeo driver, but personnaly I don't see the interest in doing
> so,
> since in my experience, MDBTools, the Unix MDB ODBC driver, under Linux
> (particularly 64bit) is too broken to be usefull
Does this apply for the new 0.7 version of mdbtools?  It seems to have a low profile because it is on github instead of sourceforge...
http://sourceforge.net/mailarchive/message.php?msg_id=29472144
Alister
