[Qgis-user] Layout-window: Grid properties: Order when using Tab-Key
Peter Schürch p.schuerch at meierpartner.ch
Mon Sep 24 23:05:51 PDT 2012
Hi List
I noticed that when I use the Tab-Key to jump from one property to the next in the grid settings the order is:
1. X-Intervall
2.  X-Shift
3. Y-Shift
Etc.
Y-Intervall is left out. This doesn't make sense to me, as you usually want to change X- and Y-Intervall at the same time (and often the same value). Potentially it would even make sense to set Y-Intervall by default to X-Intervall. So if this is what the user want's he doesn't need to change it.
Cheers, Peter
Noticed on:
QGIS-Version
1.8.0-Lisboa
QGIS-Codeversion
6416f38
Meier und Partner AG
Freiestrasse 26
8570 Weinfelden
Tel +41 71 626 51 15
Fax +41 71 626 51 26
