[Qgis-user] DXF EXPORT
Brad Nesom
gisbradokla at live.com
Thu Sep 27 12:07:46 PDT 2012
I have done some testing and I get the exact same error no matter what
data I choose to export.
Also if I export from Autocad the same data to dxf the file is quite a
few lines shorter.
I did a little looking to see what version (dxf) gdal writes buth
havent come across that info yet.
It seems the problem is that gdal starts writing objects out with a
zero handle (which is an internal guid for autodesk)
I had been using 1.8 but just installed 1.9.0 and gdal 1.7.3 and still
get the same error.
On Wed, Jun 27, 2012 at 2:09 PM, Brad Nesom <gisbradokla at live.com> wrote:
> The error might help.
> If it happens to be a line numbered erro and happens to be an ascii dxf you
> can open (as long as the mb size is not too large) in a notepad. edit the
> offending line and save.
> On Wed, Jun 27, 2012 at 12:08 PM, lt <bisnulama at hotmail.com> wrote:
>> I try to open the dxf file with AUTOCAD2007 LT and I cannot open it: I get
>> an error. then the opened file appears to be empty.
>> any suggestion?
>> laura
>> Date: Wed, 27 Jun 2012 11:39:54 +0300
>> From: Zirneklitis <eko at lanet.lv>
>> To: qgis-user at lists.osgeo.org
>> Subject: Re: [Qgis-user] DXF EXPORT
>> Message-ID: <4FEAC6DA.4090601 at lanet.lv>
>> Content-Type: text/plain; charset=UTF-8; format=flowed
>> Is it realy empty file or the exported layer can not be imported in
>> drawing applications?
>> There was a dxf export bug prior to gdal 1.9.1.
>> Now it's fixed.
>> http://trac.osgeo.org/gdal/ticket/4618
>> Karlis
>> Bis Nulama wrote:
>> Hello, how can I export a shp file to dxf format?
>> I am using qgis 1.7.4 under winXP. The save as->dxf does not work. It
>> creates the dxf file, but it is empty!
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
