[Qgis-user] First time here
Luciano La Sala lucianolasala at yahoo.com.ar
Sat Sep 29 13:16:28 PDT 2012
Hello QGIS users!
My name is Luciano and I am a wildlife researcher from Argentina. I am
rather new to the world of QGIS, so I apologize in advance for any rather
basic question.
I have several shapefiles of Argentina which I am supposed to use to make a
risk map. These vector files include:
1- Country border (line)
2- Airports (points)
3- Rivers (lines)
4- Wetlands (polygons)
5- Roads (lines)
6- Poultry farms (points)
I rasterized each of the vector files and gave each the same, new size (3993
hight and 2393 width) to fit the entire country.
Then, on each of the six maps, cells should be made to take a value of 1 if
risk factor is present (road, city, airport, wetland, and so on) and 0
otherwise. All the rasters should then be combined into one unified map. It
is my understanding that this unified map can be made using different
approaches (e.g. addition, addition and weighting, pair-wise comparisons).
In ArcView 3.2 this is done with "map calculator" of the "spatial analysis"
extension. These procedures would give a map in raster format where color
intensity of the cells is associated with the risk present in the area.
Finally, one can apply a kernel smoothing to ease interpretation of the map.
So at this point my questions are:
1) How do I assign values of 0 or 1 to pixels on each raster image? I
believe I could use RasterCalc plugin, but I just can't find a way around
this.
2) Once the above step is solved, how do I combine all maps into one using
one of the mentioned procedures (e.g. addition)?
Thank you in advance.
Luciano La Sala
Centro de Estudios Cuantitativos en Sanidad Animal (CECSA) - CONICET
Facultad de Ciencias Veterinarias - Casilda
Universidad Nacional de Rosario
Argentina
