[Qgis-user] Qgis web client resize map issue
Andreas Neumann
a.neumann at carto.net
Tue Apr 2 08:38:17 PDT 2013
Hi Mirko,
Thank you for sharing this. We decided to get rid of this right-panel
and switch to a click Popup (not a popup browser window - but a div).
So with future releases of the QGIS web client the right attribut panel
will go away anyway.
Thanks for your detailed hints. If you have other suggestions, please
provide a bug report at hub.qgis.org or - if you are familiar with
github - create a pull request with the changes.
Thank you again,
Andreas
Am 02.04.2013 12:44, schrieb mirko:
> Hi,
> who as me has problems with map panel resize in qgis web client when right
> panel (attribute panel) has been opened can try following code. I have not
> tested it with all browsers but it should work.
> I don't know if it has been fixed in last release. If not this is what i
> have done in an old version:
> 1. Css modify: add the following:
> #geoExtMapPanel { width: 100%; height: 100%; }
> #geoExtMapPanel .x-panel-bwrap { height: 100%; }
> #geoExtMapPanel .olMap { height: 100%; overflow: hidden; display: block;
> #geoExtMapPanel .olMapViewport { height: 100%; display: block; }
> 2. Make a backup of WebgisInit.js. Modify some code into WebgisInit.js:
> find this line: "geoExtMap" map object ( geoExtMap = new GeoExt.MapPanel
> Comment following lines:
> width: MapPanelRef.getInnerWidth(),
> height: MapPanelRef.getInnerHeight(),
> Add following lines:
> layout: 'fit',
> width: '100%',
> height: '100%',
> flex: 1,
> 3. Make a backup of GUI.js. Modify some code into GUI.js:
> - find this: id: "CenterPanel";
> - If not present add following line:
> * flex: 1,
> - find this line: id: 'MapPanel',
> - if not present add following lines:
> * layout: 'fit',
> * flex: 1,
> I hope this can be useful to someone.
> Regards
> Mirko
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Qgis-web-client-resize-map-issue-tp5044037.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
