[Qgis-user] Undo\Redo edits using Python
Alexandre Neto
senhor.neto at gmail.com
Tue Apr 2 09:10:54 PDT 2013
In a local python plugin I'm trying to allow Undo\Redo edits. For that I
set a *beginEditCommand()*, *endEditCommand() and destroyEditCommand().*
But I'm not being able to make it work. If you press undo, all features
added by the plugin are still there. And worst, If I stop editing and
discard changes, features disappear from attribute table, but as I start
edit again they reappear.
Please note that "l_acao" layer is a non-spatial table, and l_uni_ges is a
polygon vector layer.
I you will, please see my code below.
Thanks,
Alexandre Neto
def run(self):
# Define "acções" and "unidades de gestão" Layers from project
l_acao =
QgsMapLayerRegistry.instance().mapLayer(u'acoes20130312143950563')
l_uni_ges =
QgsMapLayerRegistry.instance().mapLayer(u'unidadesdegestao20130312143304288')
# Get layer default values from provider
# (this avoids problems with unique keys)
provider = l_acao.dataProvider()
temp_feature = QgsFeature()
attributes = {}
for j in l_acao.pendingAllAttributesList():
if not provider.defaultValue(j).isNull():
attributes[j] = provider.defaultValue(j)
else:
attributes[j] = None
temp_feature.setAttributeMap(attributes)
* # start edit command to allow undo\redo*
* l_acao.beginEditCommand("Add new actions")*
# open feature form and waits for edits
if self.iface.openFeatureForm(l_acao, temp_feature):
new_attributes = temp_feature.attributeMap()
# replicate "acção" record for each
# of the selected "Unidades de gestão"
uniges_ids = [feature.attributeMap()[1] for feature in
l_uni_ges.selectedFeatures()]
for uniges_id in uniges_ids:
new_attributes[1] = uniges_id
temp_feature.setAttributeMap(new_attributes)
new_feature = QgsFeature(temp_feature)
l_acao.addFeature( new_feature )
*l_acao.endEditCommand()*
else:
# print "Cancelled"
*l_acao.destroyEditCommand()*
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130402/69977427/attachment.html>
